300 cranking psi...........
Old Mar 9, 2005 | 06:33 PM
score10's Avatar
Default 300 cranking psi...........
i have a fully built b16 bored to 85mm with cp pistons and toda spec c cams. i just wanted to know about how much compression 300 psi would be. Thanks
Old Mar 9, 2005 | 07:04 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: 300 cranking psi........... (score10)
There's no conversion formula to give you that measurement. You need to know the bore, stroke and combustion chamber size, headgasket thickness, and the compression height of the piston you're running. FYI you should read the sticky thread at the very top of this forum about CTR pistons and compression ratios. After that you may be able to answer your own question or give us enough info about your setup to answer it for you.
90efhatch
Jul 30, 2011 05:12 PM
Robs_B18c
22
Oct 6, 2005 06:05 PM
civic ex si
Feb 10, 2004 06:09 PM
sneakychaos
Mar 6, 2003 07:42 PM
Toda Party
Oct 3, 2001 12:57 PM
