To thouse with CTR pistons - compression numbers?
Old Jan 17, 2003 | 08:10 PM
sneakychaos's Avatar
Default To thouse with CTR pistons - compression numbers?
https://honda-tech.com/zerothread?id=388936
Please see thread above and if possible make your comments there - but I'll take them either or. Basically, what type of compression numbers are you seeing with CTR pistons (std bore) in a B18C5 - stock headgasket. If you have a diff setup, please post anything that will affect comp., ie porting combustion chamber, 1 or 2 layer HG, et al.
Thanks in advance.
Old Jan 18, 2003 | 09:39 AM
Default Re: To thouse with CTR pistons - compression numbers? (sneakychaos)
..anyone?
Old Jan 18, 2003 | 10:31 AM
Zeus's Avatar
...no personal knowledge, but in past posts it seems that it was right around 12:1 at a compression check of 300 psi... or maybe I'm thinking of other higher compression builds?
[Modified by Zeus, 4:03 PM 1/18/2003]
Old Jan 18, 2003 | 10:56 AM
sgT's Avatar
sgT
what, my answer not good enough for you?
Old Jan 18, 2003 | 11:03 AM
TypeR 599's Avatar
Default Re: To thouse with CTR pistons - compression numbers? (sgT)
sgt, so w/ jun 3's and stock compression, the numbers would be higher than stock because of the cams?
btw- on my car w/ stock cr and jun 3's, i got 1-4: 230, 225, 235, 230
is that too low?
[Modified by TypeR 599, 12:04 PM 1/18/2003]
Old Jan 18, 2003 | 11:10 AM
sgT's Avatar
sgT
Default Re: To thouse with CTR pistons - compression numbers? (TypeR 599)
depends on the cams. could go either way.
your numbers seem fine.
Old Jan 18, 2003 | 12:44 PM
Steve I appreciate your response. Don't know why you seem offended that I'm looking for more responses though... *shrugs*
You said over 300... how much over? 301? 399? I'm hitting 280 +/- 5 across all 4 cyl's... for some reason I thought it should've been higher. Thats why I'm asking.
e: that was with JDM R cams, stock 3 layer HG, b18c5 with ctr pistons. ported comb. chamber. Have not checked yet since putting the B's in. It should go up?
[Modified by sneakychaos, 4:45 PM 1/18/2003]
Old Jan 18, 2003 | 12:47 PM
sgT's Avatar
sgT
like i said, cams and cam timing will play a large role.
280 sounds right to me though.
Old Jan 18, 2003 | 12:50 PM
Agreed... which is why I'm asking these questions. Trying to learn and understand why and how this will affect compression like it does.
Cool. Was hoping everything went together well. Now, as soon as I can get my tensioner bolt out to re-tighten the timing belt, I'll hopefully hit the dyno for some cam tuning, too.
Old Jan 18, 2003 | 01:06 PM
Chubz's Avatar
with CTR pistons and JUN III in my b18c1 block with b16a head im hitting over 300+ in all cylinders
Old Mar 6, 2003 | 07:42 PM
mojo6940's Avatar
Default Re: To thouse with CTR pistons - compression numbers? (Freakzilla)
In a GSR I built with skunk .5mm oversized high compression valves, and ctr pistons with stock cams, my snap on guage, which reads only till 300psi, went past the 300psi mark to somewhere that looked like it would be 325-350psi. thats some hella compression
GSR in Progress
Jan 10, 2006 06:37 PM
Robs_B18c
22
Oct 6, 2005 06:05 PM
itr1244
May 12, 2005 10:30 AM
vti444
10
Jul 20, 2004 05:03 AM
JBk24crx
Aug 6, 2003 11:26 PM
