which IM for turbo h series
Old Mar 9, 2005 | 04:13 PM
bjfisher's Avatar
Default which IM for turbo h series
which intake manifold is best for a built and turboed h23 vtec?i'm looking at venom,jg,str,and golden eagle.....anyone have any suggestions or anything?
**EDIT**also one that fits well in a eg civic.and what are the ups and downs of each?
Modified by bjfisher at 5:29 PM 3/9/2005
Modified by bjfisher at 5:34 PM 3/9/2005
Modified by bjfisher at 5:38 PM 3/9/2005
Old Mar 9, 2005 | 07:27 PM
LudeyKrus's Avatar
Better check in the hybrids forum; we won't have a clue which ones will fit in a civic w/ their closer firewalls.
All I know is the Skunk2 manifold won't fit; others may not either.
Old Mar 9, 2005 | 10:44 PM
edulerp97's Avatar
Default Re: (LudeyKrus)
My boy has and Venom Intake manifold.....He loves it....
Old Mar 10, 2005 | 10:48 AM
bjfisher's Avatar
ok well aside from fitment, which would be the best to go with?i'm leaning towards JG right now....
Old Mar 10, 2005 | 12:36 PM
jakeiscool's Avatar
Banned
Default Re: which IM for turbo h series (bjfisher)
OBX makes a stainless one that is made for boost apps.(knockoff venom same performance 1/2 price.)
Old Mar 10, 2005 | 01:18 PM
Pikachu's Avatar
I dunno what'cha talking about. The Skunk2 manifold fits. Just take a mallet to the firewall and make sure you don't mess up the heater core. I had pics of it fitting in a civic just gotta look for it.
Old Mar 10, 2005 | 01:39 PM
edulerp97's Avatar
Default Re: (Pikachu)
He right about the OBX...I always say you get what you pay for....
Old Mar 10, 2005 | 01:41 PM
LudeyKrus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pikachu &raquo;</TD></TR><TR><TD CLASS="quote">I dunno what'cha talking about. The Skunk2 manifold fits. Just take a mallet to the firewall and make sure you don't mess up the heater core. I had pics of it fitting in a civic just gotta look for it. </TD></TR></TABLE>
Wow man, sounds like it just bolts right in there!
It does NOT bolt right on, and you yourself just said it. Anything that requires a BFH to make fit is NOT a bolt-right-up affair and should be left to those who are willing to beat their own cars senseless with a large piece of steel mounted on a long piece of lumber.
Old Mar 10, 2005 | 02:11 PM
Pikachu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">
It does NOT bolt right on, and you yourself just said it. Anything that requires a BFH to make fit is NOT a bolt-right-up affair and should be left to those who are willing to beat their own cars senseless with a large piece of steel mounted on a long piece of lumber. </TD></TR></TABLE>
Yea, that's very true. Can't beat originality though. It's not a lot of banging in of the firewall. I'm actually gonna attempt this on my civic in a few weeks. We'll see.
Old Mar 10, 2005 | 03:23 PM
bjfisher's Avatar
obx wasnt an option on my list due to the cheap quality.as far as skunk2 ive heard nothing but bad things about that manifold and its def not the best choice for a boosted car.
but anymore help on the ones i listed above would be great
Old Mar 12, 2005 | 12:56 PM
edulerp97's Avatar
Default Re: (bjfisher)
Skunk 2 is very good, but for turbo you should go with Venom or JG....
Old Mar 12, 2005 | 02:00 PM
LudeyKrus's Avatar
So you're not considering the OBX because of its "poor build quality", yet you have never even seen it?
I'll save the flaming for now and explain it to you. OBX contracts out its products to be made by other companies; they simply slap their badge on there and sell it. Their old headers sucked. Their new cams are pretty damned good. So are their LSD's, and there's a LOT more that can go wrong in an LSD if put together badly.
An intake manifold encounters very little heat compared to most parts of an engine; it doesn't move, it doesn't get heat cycled at high temp's, and generally is one of the last things that will fail on a motor.
The OBX design looks almost exactly like those of the other "big name" intake manifolds for boost.
If i were boosting, I would buy an OBX intake manifold. But do what you want w/ that money of yours
Old Mar 12, 2005 | 02:22 PM
bjfisher's Avatar
correction, i have seen it.never said i didnt.
i listed manifolds im interested in that cost 500-600im using a 70mm throttle body.i havent cheaped out on the rest of my setup, why would i now.i have a built h23 block and h22 head with a turbonetics 60-1 p-trim .81ar
you pay for what you get for.obx is cheap.and no, their lsd's are ****.guess what i'm using.quaif.good products ARENT cheap.
i can appreciate the suggestion, but i clearly turned it down.so, if i can actually get help with the ones i listed, thanks, if not, so be it
Old Mar 12, 2005 | 02:31 PM
ralpheezy's Avatar
i would say venom or golden eagle. i have no personal experience but i know that Oaksracing uses venom and that precision's company uses golden eagle. correct me if i'm wrong.
Old Mar 12, 2005 | 02:36 PM
bjfisher's Avatar
cool thanks
right now i'm leaning towards str.from what i've read in reviews, venom(which i originally really wanted) doesnt work as well and easy with stock sensors and whatnot.but str,golden eagle, and ac appear to be IDENTICAL.and since im using a str fuel rail and str tb, i might as well use their mani too
bring on more opinions tho
Old Mar 12, 2005 | 08:29 PM
LudeyKrus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bjfisher &raquo;</TD></TR><TR><TD CLASS="quote">you pay for what you get for.obx is cheap.and no, their lsd's are ****.guess what i'm using.quaif.good products ARENT cheap.
i can appreciate the suggestion, but i clearly turned it down.so, if i can actually get help with the ones i listed, thanks, if not, so be it</TD></TR></TABLE>
No problem; you are clearly one of the majority of the "tuners" that honestly believes that throwing money at a car will make it fast, and can't understand the concept that a company copying a design and selling it for cheaper can be, in fact, just as good as the copied design.
I'll leave you to pointlessly throw your money away so you can have the brand name you want.
Old Mar 13, 2005 | 07:24 AM
bjfisher's Avatar
thanks
Old Mar 13, 2005 | 07:31 AM
mgags7's Avatar
BFH </TD></TR></TABLE>
wow....im glad someone else shares the BFH nomenclature....everyone i know is has no idea what BFH means.....
oh yeah and we should have known it will fit, you just need to use a BFH to make fit...DUH!
oh and to the thread creator....if you invested as much time into thought as money into your car, you would realize that there is a Forced Induction forum on this website.....so go ask there.....
Also, when you put periods at the ends of sentences. You put a space in between and capitalize the first letter of the next sentence. Oh, and quaife is the brand....you spent $1000 on an LSD from them and you cant even spell the name right.....
Old Mar 13, 2005 | 09:31 AM
JDM H23A's Avatar
Check out the "Honda Civic Project" at http://www.cj-motorsports.com My buddy used a Golden Eaqgle manifold with a turbo H22A EG and it made nice power
Old Mar 13, 2005 | 09:38 AM
bjfisher's Avatar
great, thanks, looks as if their is decent room with it? those are hasport mounts im guessing?
Old Mar 13, 2005 | 10:06 AM
JDM H23A's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bjfisher &raquo;</TD></TR><TR><TD CLASS="quote">great, thanks, looks as if their is decent room with it? those are hasport mounts im guessing?</TD></TR></TABLE>
They're HCP mounts
Old Mar 13, 2005 | 10:08 AM
bjfisher's Avatar
ok cool
anyhow, i'm jus not seeing a dif in str,ge,and ac....anyone wanna change my mind?
Old Mar 13, 2005 | 10:36 AM
ebp 99 si's Avatar
i have the golden eagle on my hatch
Old Mar 13, 2005 | 11:25 AM
h22 civic's Avatar
Default Re: (ebp 99 si)
g/e no probs at all
Old Mar 13, 2005 | 11:30 AM
bjfisher's Avatar
damn anyone know what the dif (if any) between ge and str?seems to me to be the same, and since im using str cam gears,fuel rail and tb i might as well use their manifold....lol
you guys got pics?
