Going Through Coolant Way Too Often......
Old Mar 9, 2005 | 04:03 PM
digital sol's Avatar
Default Going Through Coolant Way Too Often......
alright, i was wondering what can cause a motor to use up Coolant to often? I have a 99 jdm itr swap, it has around 18k miles and dosnt burn any oil between oil changes, however it seems im filling up the coolant resevoir once a week and every time i go to add more at the 7 day interval its completely empty or below the min line, as stated my car runs like a champ, dosnt burn any oil, no coolant or anything like that in my oil or visa-versa, my fan kicks on and my heat needle never goes above 1/2 way
heres some info to keep in mind
im usuing a Single Core del sol Radiator w/stock del sol resovoir, and fan
im not just gonna hop on the bandwagon and replace the radiator unless thats for sure the problem because if i do replace it "its brand new" im gonna wanna get an aftermarket racing spec radiator and slim fan set-up which isnt really cheap. But im hoping its not because this radiator is only 2-3 months old.
thanks for the help guys
Old Mar 9, 2005 | 04:09 PM
vtec.dc2's Avatar
Default Re: Going Through Coolant Way Too Often...... (digital sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by digital sol &raquo;</TD></TR><TR><TD CLASS="quote">alright, i was wondering what can cause a motor to use up Coolant to often? I have a 99 jdm itr swap, it has around 18k miles and dosnt burn any oil between oil changes, however it seems im filling up the coolant resevoir once a week and every time i go to add more at the 7 day interval its completely empty or below the min line, as stated my car runs like a champ, dosnt burn any oil, no coolant or anything like that in my oil or visa-versa, my fan kicks on and my heat needle never goes above 1/2 way
thanks for the help guys</TD></TR></TABLE>
if no visible leaks. or white smoke. then coolant pressure test will help find leaks
Old Mar 9, 2005 | 04:44 PM
2HEKTK's Avatar
As said, I would get a radiator specialist to run a preasure test on the system just to make sure there is no visable leaks from the plastic tank, hoses etc If that comes up fine maybe a TK test?
Old Mar 9, 2005 | 04:50 PM
ZygSpeed's Avatar
Head gasket?
Old Mar 9, 2005 | 05:46 PM
onePOINTsix's Avatar
Default Re: Going Through Coolant Way Too Often...... (zygspeed)
you can probally rent a cooling system pressure tester from autozone. attatch it to where your radiator cap goes and pressurized it to 15psi, wait 5min and if the pressure droped you have a leak. If it didnt drop then it's probally a HG becasue they are weird like that. Meh my .02
Old Mar 9, 2005 | 07:04 PM
Default Re: Going Through Coolant Way Too Often...... (onePOINTsix)
thank-you, ill call autozone tomarrow and see if they have it, its probably just a leak, i see no reason why my headgasket would leak and it dosnt have the symptoms of a bad head gasket
Old Mar 9, 2005 | 07:24 PM
B2FiNiTY's Avatar
water pump? Has to be a leak or burn somewhere.
Old Mar 9, 2005 | 08:00 PM
Bbasso's Avatar
Have you checked the passenger side floor for dampness?
Just a thought... Heater Core bad and leaking.
Old Mar 12, 2005 | 11:56 AM
Default Re: Going Through Coolant Way Too Often...... (Bbasso)
checked everything today, cracked hose and im also usuing a single core raditor which has a smaller diameter outket/inlet then the block so there is probably some pressurized spray when pressure builds up sense the motor/radiator have diff inlet/outlet sizes but im usuing hoses to match the motor
Old Mar 12, 2005 | 11:59 AM
ZygSpeed's Avatar
Glad you found the problem and that it wasn't more serious or difficult to fix.
chansta
15
Oct 12, 2010 02:29 PM
team 15
May 9, 2007 01:09 PM
vc
Apr 4, 2006 06:44 AM
Evanmb44
May 8, 2005 06:14 PM
PearlWhiteAccord
Sep 25, 2002 12:15 PM
