Removing bumper from 4th Gen
Ok, i have all the screws taken off except these 3 screws under each headlight. If i cant take the headlight off until i take the bumper off, then how do i get to these three screws? There are three screws directly underneath the headlight on both sides and i have no idea how to get to them. None of the instructions i have read have even mentioned these screws. Advice please
i always removed the 2 bolts on the side of each headlight to loosten em up and then i could pull it up enough to get to the screws underneath it
I've taken my front bumper off many times, I don't remember needing to remove these screws. There's a walkthrough on absoluteprelude.com that I used. It's the one for the JDM headlight swap. Look it up.
yeah, i figured it out like right after i posted that >_<. Now my problem is that i dont have a long enough extenion to get to the last 2 bolts
you also need to get the two bolts behind each turn signal, if you haven't already.
I think part of your trouble is from the fact that you are expecting the bumper cover to come off by itself. It doesn't - the metal bumper comes off with it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Greyout »</TD></TR><TR><TD CLASS="quote">you also need to get the two bolts behind each turn signal, if you haven't already.
I think part of your trouble is from the fact that you are expecting the bumper cover to come off by itself. It doesn't - the metal bumper comes off with it.</TD></TR></TABLE>
if im understanding you correctly, the whole bumper support has to come off with the bumper? shouldnt the plastic urethane or whatever material it is just come off by itself?
yeah you need the take off the bumper support with the cover. the cover doesnot come off the car by it self.
for the bumper support there are two bolts on each side behind te front bumper turn signals. then there is nut on each side right be hind the headlight.
I believe thats it for the big bolts for the bumper support. besides all the bs little plastics under the bumper and in the wheel well.
