Aebs manifold, BBK throttle body & throttle cable ??
Old Mar 9, 2005 | 03:52 PM
Autoworks's Avatar
Default Aebs manifold, BBK throttle body & throttle cable ??
I am putting together my AEBS intake manifold x/ BBK tb and using my stock B16 throttle cable bracket, but my LS throttle cable and it seems to have entirely to much slack (about 3 inches). Do I need to get a Type R or shorter cable?? Or is there a different cable bracket I need?? Any suggestions?? This is all going on a JDM B16A in my 89 CRX
Old Mar 9, 2005 | 05:00 PM
pwrofdrm's Avatar
Default Re: Aebs manifold, BBK throttle body & throttle cable ?? (Autoworks)
If you have some scrap metal laying around you may be able to ghetto rig a bracket to work...
If you need a throttle cable though give me a call tommorow (number in sig) and I can get you one cheap
-Evan
Old Mar 9, 2005 | 07:27 PM
Autoworks's Avatar
Default Re: Aebs manifold, BBK throttle body & throttle cable ?? (lax1185)
I'll give you a call.
Any more info, anyone??
Old Mar 10, 2005 | 03:44 AM
Autoworks's Avatar
morning bump
Old Mar 10, 2005 | 07:53 AM
Reelizmpro's Avatar
Interesting...most people don't have enough slack and have to adjust the cable. I suggest trying to adjust it before replacing the entire cable. I have an AEBS IM with bored LS TB and I modified the stock cable bracket slightly to work on the manifold. I also mounted the intake temp sensor upside down for more clearance.
Old Mar 10, 2005 | 08:03 AM
Autoworks's Avatar
Default Re: Aebs manifold, BBK throttle body & throttle cable ?? (Reelizmpro)
Yeah, I mounted my sensor upside down and ordered a 99 LS fuel rail. I have about 3" slack in the cable so I may try fabbing a bracket tonite. I just spoke to my friend at Acura, and they said the ITR cable and LS cable should be about the same lenght, they just mount differently on the corresponding manifolds.
What did you do to bypass coolant lines under the TB?
Again, thanks for the help
Old Mar 10, 2005 | 08:23 AM
Deetz's Avatar
Crazy Honda Guy
More than likely just buying a ITR cable braket from the dealer for $5 will solve your problem.
Old Mar 10, 2005 | 08:26 AM
Autoworks's Avatar
Default Re: (Deetz)
Do you know that the ITR bracket is longer than the B16 bracket? I'll search the "Engine Bay pic" thread to see if I can spot one. But if it is longer than I would definately do that.
Old Mar 10, 2005 | 12:44 PM
Autoworks's Avatar
Default Re: (Autoworks)
bump
Old Mar 10, 2005 | 04:19 PM
Autoworks's Avatar
Thanks for the help
Lax, I called you today, but you weren't in yet.
I fabbed up a bracket and polished it today, it moved the OE bracket over 3", looks good and the throttle cable seems to be exactly in the right spot, so I'll just see how well it works when I get ready to drop the motor in.
k20o2o4civic
Mar 3, 2009 07:22 PM
skeezy
Dec 10, 2007 10:21 AM
SohcVtaak
Sep 13, 2007 08:34 AM
Topdawgg
Jun 29, 2007 07:52 PM
mustbenu
Dec 30, 2003 03:38 PM
