Water in headlights - 97 Civic
Old Mar 9, 2005 | 03:42 PM
GoLowDrew's Avatar
Old Member
25 Year Member
Default Water in headlights - 97 Civic
I now have moisture build up in one of my headlight on 97 Civic. It's never been opened or mod for clear corner. It's all stock. I have not wash my car, but I'm guessing the wet winter, and the fact that my car was outside for many days may be the cause. Either case, what can I do since it now don't seem to go away (it comes back)?
TIA
Old Mar 9, 2005 | 03:45 PM
HitEm'Up's Avatar
Default Re: Water in headlights - 97 Civic (GoLowDrew)
You may just want to replace the headlight now
Old Mar 9, 2005 | 03:49 PM
EVIL Hx Coupe's Avatar
Default Re: Water in headlights - 97 Civic (98JRSChatch)
The seatant on your headlight crapped out somewhere, that's why you get that condensation. You can either redo the whole headlight with new silicon, or get some new one's if they're worn out and it's not worth wasting your time.
Old Mar 9, 2005 | 07:26 PM
GoLowDrew's Avatar
Old Member
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98JRSChatch &raquo;</TD></TR><TR><TD CLASS="quote">You may just want to replace the headlight now </TD></TR></TABLE>
Water may cause the bulb to explode. So that's $5.00. Can it do anything other damage? I recall a headlight was like $350. That's a lot of $$$ when "nothing" is wrong.
What are the effects if I just leave it?
TIA
Old Mar 9, 2005 | 07:30 PM
93civicsedan's Avatar
Try putting the headlight in a hot room or use a blow dryer to get rid of some of the condensation. Or you can just open them up and reseal them with silicon and theyll be good as new.
Old Mar 9, 2005 | 07:31 PM
hothotpete's Avatar
buy, not one, BUT 2 NEW on eBay, thats what i did. 125 for 2 oem headlights.
Old Mar 9, 2005 | 07:34 PM
.Kevin.'s Avatar
put it in the oven at like 200 degrees for about 5-8 min then open it up put more sealant in it close it back up seal around the outside and that should do it
Old Mar 11, 2005 | 08:43 AM
twinbros's Avatar
1.bake them in the oven
2.Open and remove stupid amber reflector
3. Reseal with good quality silicone
Old Mar 11, 2005 | 08:47 AM
Bcuz's Avatar
Buy a new headlight, it'll cost you though.
popejooie
Apr 13, 2010 07:14 PM
standbackimapro
Mar 9, 2008 02:46 PM
TurboGS-R
Nov 16, 2006 03:08 PM
prostreetonline
Apr 4, 2006 10:24 AM
3R1C
16
Jul 26, 2004 07:24 AM
