holding down CF hoods with just hoodpins? no hood latch. does it work?
Old Mar 9, 2005 | 01:57 PM
eMpAtHy's Avatar
Default holding down CF hoods with just hoodpins? no hood latch. does it work?
i was wondering if i could just hold down a VIS CF hood with just hoodpins and without the hoodlatch. i got into a small accident and then it isnt working. i was wondering if i could hold down the hood with 2 sparco hoodpins. i think im going to take a chain and then chain my hood to the frame of my car too. Probably going to bring the chain through the loop where the hood latch goes to. i say Good luck to those people trying to pop my hood
but will it be able to hold without the hood latch and just 2 hood pins?
can i just drill a hole without a dremel and just a regular drill?
Old Mar 9, 2005 | 02:17 PM
redhonda91's Avatar
Default Re: holding down CF hoods with just hoodpins? no hood latch. does it work? (eMpAtHy)
i know of 2 people that have done this...one kid had a ef 'n' the other has a jetta...i believe they both broke there latches so they just rocked wit the pins...the one with the jetta says it comes up a lil but he hasent tried to bring the rod down...so yes it will work...i dont know if i would recommend doing it...but thats up to u..........................
Old Mar 9, 2005 | 02:21 PM
SIRIUS's Avatar
Definately shouldn't be a problem. Weight reduction yO!
Edit: Use a glass/tile bit if you're going to drill into the hood. Be a good idea to drill through tape also.
Old Mar 9, 2005 | 02:23 PM
NickW's Avatar
Default Re: holding down CF hoods with just hoodpins? no hood latch. does it work? (SIRIUS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIRIUS &raquo;</TD></TR><TR><TD CLASS="quote">Definately shouldn't be a problem. Weight reduction yO!
Edit: Use a glass/tile bit if you're going to drill into the hood. Be a good idea to drill through tape also. </TD></TR></TABLE>
Damn, I never thought about a glass bit for my buddies hood...we went so slow on that thing. But yes, he is running 2 pins w/o a latch...hasn't had a single problem in the past 6-7 months.
Old Mar 9, 2005 | 02:28 PM
variable's Avatar
That would scare me New hood latch is $35 at the dealership
Old Mar 9, 2005 | 02:32 PM
NickW's Avatar
Default Re: holding down CF hoods with just hoodpins? no hood latch. does it work? (variable)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by variable &raquo;</TD></TR><TR><TD CLASS="quote">That would scare me New hood latch is $35 at the dealership</TD></TR></TABLE>
Why? If you install them properly, pins work great.
Old Mar 9, 2005 | 02:43 PM
variable's Avatar
Default Re: holding down CF hoods with just hoodpins? no hood latch. does it work? (NickW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NickW &raquo;</TD></TR><TR><TD CLASS="quote">
Why? If you install them properly, pins work great. </TD></TR></TABLE>
I guess I just worry I have sparco pins and a hoem latch and Im still scared when i get on the highway
Old Mar 9, 2005 | 02:45 PM
NickW's Avatar
I guess I just worry I have sparco pins and a hoem latch and Im still scared when i get on the highway</TD></TR></TABLE>
I wouldn't worry...the only car I've ever been in that had the hood fly up was a 89 prelude that was bone stock, inside and out.
Old Mar 9, 2005 | 03:12 PM
eMpAtHy's Avatar
would it be fine if i just used a regular metal bit?
i dont want to go out and buy a glass/tile bit.
kornerk12
Aug 24, 2006 11:04 AM
EP34ME
Aug 5, 2005 06:11 AM
93HatchCali
86
Nov 25, 2003 08:33 AM
Gusto222
Feb 26, 2003 02:50 PM
