ITR Rear LCA's on a 97 GSR???
Old Mar 9, 2005 | 01:46 PM
1JDMDOMINICAN's Avatar
Default ITR Rear LCA's on a 97 GSR???
Ok, I want to get the TEIN RA suspension for my 97 GSR. Obviously, they only make it for the ITR so I have to get Type R rear lower control arms. My question is, if I get the ITR LCA's, do I have to use the Type R rear sway bar or can I keep my factory GSR rear sway bar? I ask because I'm not sure if the Type R and GSR have different mounting points for the rear sway bar...
ThanKZ!
Old Mar 9, 2005 | 02:57 PM
95LSDOHC's Avatar
Default Re: ITR Rear LCA's on a 97 GSR??? (mugenda6)
good question...anyone know?
Old Mar 9, 2005 | 02:59 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: ITR Rear LCA's on a 97 GSR??? (95LSDOHC)
You can keep the GSR sway bar with the ITR LCA's. But you'll eventually want to switch to a bigger bar than the GSR bar for the better handling benefits.
But to answer your question, yes. Both bars utilize the same mounting points and share the same end links.
Good luck!
stuie08
Mar 28, 2010 01:49 PM
meric0786
Suspension & Brakes
Apr 24, 2009 01:24 PM
silver_gs-R
Suspension & Brakes
Jun 16, 2007 05:15 PM
EGTeK
36
Apr 9, 2003 10:17 PM
Mr. Softee
Jun 25, 2002 03:01 PM
