Intake Manifold Bracket?
Old Mar 9, 2005 | 10:48 AM
Targa4Life's Avatar
Default Intake Manifold Bracket?
Is the bracket which appears to be holding up the back side of the intake manifold really nessesary?? Its the one underneath which does'nt look to have any other purpose besides support. If the exhaust can be supported by just the flange than you would think that the intake manifold could as well.
Old Mar 9, 2005 | 11:06 AM
3.504's Avatar
Default Re: Intake Manifold Bracket? (Targa4Life)
i always take mine off.. i hate them, they get in the way during an oil change. i wouldn't recommend lifting the motor up by the intake mani or exhaust mani anyways, but especially after you take the bracket off. other than that, i run no bracket, i dont even think aftermarket manifolds have holes drilled to mount to the bracket. my skunk2 for my LS didn't.
Old Mar 9, 2005 | 11:21 AM
631 Teggy's Avatar
Default Re: Intake Manifold Bracket? (3.504)
No need for it. Does fine in the garbage.
Old Mar 9, 2005 | 11:35 AM
B2FiNiTY's Avatar
Default Re: Intake Manifold Bracket? (631 Teggy)
You will be fine without it.
Old Mar 9, 2005 | 12:22 PM
Honda Hick's Avatar
What engine?
When I installed my BLOX IM on my GSR it was significantly lighter than the stock one. The stock GSR IM is pretty damn heavy with all the extra butterflies and ports in it. I would leave the bracket if you have a GSR IM, it doesn't really get in the way, plus it holds the heater hose hard lines.
Old Mar 10, 2005 | 07:00 AM
Targa4Life's Avatar
Default Re: Intake Manifold Bracket? (Honda Hick)
I have the power plus Typhoon intake manifold and it is'nt very heavy (not heavy enough to require an extra bracket anyway) so I think I will leave it off. The bolts are hard to get into place.
anthony90si
Jul 2, 2006 09:19 PM
trellix78
Dec 18, 2004 07:24 PM
ms1motorsports
Sep 30, 2004 12:20 PM
Beave0101
Jul 13, 2003 07:11 PM
b20guy
Sep 13, 2002 03:12 AM
