Running Rich??
Old Mar 9, 2005 | 09:38 AM
JoeHonda95's Avatar
Default Running Rich??
I think that my 95 VTEC is running rich, There is black **** all over my exhaust pipe, and there is always a amsll stream of black smoke when im ON IT!
Last night i was racing a buddy with a CRX and when i shifted into third, i slammed in the clutch about 7000rpm and heard a really loud bang, and there was a thick stream of black smoke out the tail...
I have a AEM CIA, DC header, high flow cat, 140K miles, not so good O2 sensor and plugs/wires, anyone know what i can do to check this? or what it might be?
Old Mar 9, 2005 | 09:45 AM
The Phil's Avatar
Default Re: Running Rich?? (JoeHonda95)
Preludes run rich stock, but this seems kind of excessive...try resetting the ECU and see if it leans it out. While you're at it, grab a VAFCII and lean it out to make a bit more power.
Old Mar 9, 2005 | 09:46 AM
98TypeSH's Avatar
im willing to bet its 140K miles of being beat on and forgetting about regular maintenance. I saw a black 4th gen VTEC this morning on Moulton, was that you ?
Old Mar 9, 2005 | 09:56 AM
JoeHonda95's Avatar
Default Re: Running Rich?? (98TypeSH)
No, it wasnt me, cause im in class right now at Riverside Community College....but i live about 1 mile away from Moulten and i race along that road all the time LOL but i have seen a black Si in Laguna Niguel, he says its got a HKS turbo....it sounded sick, but he wouldnt race me.... Where do you live?? did you go to high school around OC??
I need to get a VAFC for sure.... but if it is the 140K being beaten, then what do i need to do to fix it?? I know that there is not excessive Blow-By, so my rings are good....but i need to check compression....
could bad wires/plugs/O2 sensor all together cause a rich condition??
Old Mar 9, 2005 | 10:03 AM
98TypeSH's Avatar
i got a compression tester. Well you dont know for sure if you actually are running rich. Pull the plugs and check them out. Brown is normal, black is rich, white is lean.
There really isnt anyone around this area that has a "fast car". You have much to learn oh new HT member. I used to go to Aliso Niguel.
Old Mar 9, 2005 | 10:29 AM
JoeHonda95's Avatar
I also went to aliso....i graduated 03...i used to have a red 88' camaro, with a good paint job, exhaust, and blackouts....you mighta seen it....but i crashed it a while ago
I do have much to learn....and i know that there are not that many 'fast' cars around....i know mines not that fast....but its stock, and i know that. The only thing ive done that actually made a diff is my Spec stage 3 clutch and Fidanza fly... best thing ever.
so if you live in Laguna Niguel area, we should meet up sometime, id love to borrow your compression tester.... and my plugs are full of black soot...but looks like the outer layer like on the terminal and the coil are whiteish.......
Modified by JoeHonda95 at 11:41 AM 3/9/2005
Old Mar 9, 2005 | 12:30 PM
sup gurl's Avatar
Preludes running rich is no news, but streams of black smoke-
I get on my 97 and the worst thing to happen is just black **** on my back bumper.
Old Mar 9, 2005 | 01:28 PM
Odessa's Avatar
Default Re: Running Rich?? (egpbb6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egpbb6 &raquo;</TD></TR><TR><TD CLASS="quote">
Same here.
Old Mar 9, 2005 | 01:38 PM
integra15's Avatar
Default Re: Running Rich?? (Odessa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Odessa &raquo;</TD></TR><TR><TD CLASS="quote">
Same here.</TD></TR></TABLE>
Me also, and from what I have grecently learned, a VAFC wont let you lean out anything except WOT. Can anyone confirm this?
Old Mar 9, 2005 | 02:02 PM
Boarderx192's Avatar
Default Re: Running Rich?? (integra15)
I also have black **** all over my bumper. Ill wash it and 6 hours later, its back to "normal"
Old Mar 9, 2005 | 02:11 PM
Odessa's Avatar
Default Re: Running Rich?? (Boarderx192)
And that **** is really sticky, 'cause if you don't wash it regularly (once every 1-2 weeks), it will be impossible to completely get it off...especially on my pearl white bumper.
Old Mar 9, 2005 | 02:16 PM
dmxsoulja3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra15 &raquo;</TD></TR><TR><TD CLASS="quote">Me also, and from what I have grecently learned, a VAFC wont let you lean out anything except WOT. Can anyone confirm this?</TD></TR></TABLE>
Not true it can tune in 500 rpm incriments..
Old Mar 10, 2005 | 09:45 AM
JoeHonda95's Avatar
Default Re: Running Rich?? (dmxsoulja3)
I dont ALWAYS have smoke coming out of the tailpipe, my buddies have noticed it when im in VTEC tho....and then the other day when i freakin ignited the extra fuel in the exhaust...i think thats what happened??!!
So if i got a VAFC... might i be able to lean out my engine enough to compensate for the 'real' problem?? which im not sure of yet???
if so...should i go for the VAFC I or II?? is there a big diff between the two?? i am loow on money, so if i can get a VAFC I for a lot cheaper, then would that work??
Old Mar 10, 2005 | 09:46 AM
The Phil's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dmxsoulja3 &raquo;</TD></TR><TR><TD CLASS="quote">
Not true it can tune in 500 rpm incriments..</TD></TR></TABLE>
WOT isn't redline. You can be WOT at 500rpms.
kornerk12
Mar 19, 2006 05:26 PM
GDM Z28
Jan 25, 2005 04:15 AM
99shRIGGS
Dec 29, 2004 08:49 PM
ZoNe_HKS
Feb 11, 2003 06:52 PM
echo999
Jan 12, 2002 03:43 PM
