75 shot in JDM H22A?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteLude »</TD></TR><TR><TD CLASS="quote">wouldn't recommend it. it'll work, but its terrrrible on ur motor</TD></TR></TABLE>
Nitrous is not black magic. It is just like any other power adder. If you compensate for the extra power, you will be fine.
Nope, not true. It will run fine. Just make sure you have a good fuel pump and the motor is in good shape. Many guys have run good sized shots on h22s for long time with no problems.
Search; i've seen this covered in here a few times before.
For comparison, though: there's a girl on PreludeOnline.com that was running a direct-port 125 shot on her internally-stock H22, and had no problems.
He's right I have a friend down here in El Paso, Tx running a 100 shot Direct port from NX and he is doing fine. (Stock Internals) He upgraded his fuel system except for the injectors.......
Umm...i've been running an NX 75 shot on my jdm h22a for 2 years...absolutely NO problems.
100 shot (wet kit) with 110 octane and a fuel pressure regulator, also had a walbro 255, msd coil, msd ignition, zex plugs, msd plug wires. Ran about 5 bottles of nitrous using the 100 shot and about 3 bottles with the 75 shot. Then about 5 months of 9-10lbs of boost on my JDM H22A.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by edulerp97 »</TD></TR><TR><TD CLASS="quote">Man If you do go nitrous go NX Direct port. Best Kit money can buy........
agreed
</TD></TR></TABLE>agreed
know my boy did 75shot, then 100, then 125, still stock.......
then @ 150 engine fried the rings.. 3 other friends with h22/23's run 100's all day reliably, and I mean go visit the shop for refils 2 or 3 times a day sometimes. Oh make sure you use the frigin bottle heater and monitor your pressure @ the bottle.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by edulerp97 »</TD></TR><TR><TD CLASS="quote">So in other words you will be alright witha 75 upto a 125 shot. To stay safe and not to push your luck go with a 100 shot. </TD></TR></TABLE>
I will agree with that. Good sum up
mhgleitz
Nov 19, 2003 03:33 PM
