HELP!! MY ACCORD IS CRAZY!!!!!!!!
Old Mar 9, 2005 | 07:31 AM
nakyama's Avatar
Default HELP!! MY ACCORD IS CRAZY!!!!!!!!
I bought this 2000 honda accord EX 4 cylinder 5 speed from a private seller. About a month later my car started revving repeatedly from 1500 rpms to 2500 rpms when i was in neutral!!!
The shop replaced the vacuum hose, transmission fluid, and idle valve. STILL DOES IT!! Brought it back in today and they say a bad o2 sensor? COuld this really cause my car to rev like that while idling and then completely die on my mid-road??? I NEED HELP!!!
I think its just a lemon!
Old Mar 9, 2005 | 07:54 AM
Filthy Focker!'s Avatar
Default Re: HELP!! MY ACCORD IS CRAZY!!!!!!!! (nakyama)
It could. Is your check engine light on?
fs
Old Mar 9, 2005 | 08:34 AM
Hondaman56's Avatar
From: Filthadelphia City of Brothers and Love, PA, USA
NO, your thermostat is stuck in the open position, have it replaced.
Old Mar 9, 2005 | 12:02 PM
fw190bvi's Avatar
Default Re: HELP!! MY ACCORD IS CRAZY!!!!!!!! (Hondaman56)
that what the car does to help warm the engine up....if its doing it when you first start it up during the winter, thats normal, if its while driving, its the thermostat
Old Mar 9, 2005 | 04:53 PM
JDM.Accord's Avatar
Default Re: HELP!! MY ACCORD IS CRAZY!!!!!!!! (fw190bvi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fw190bvi &raquo;</TD></TR><TR><TD CLASS="quote">that what the car does to help warm the engine up....if its doing it when you first start it up during the winter, thats normal, if its while driving, its the thermostat</TD></TR></TABLE>
2500 to warm up?? Neither of my Accords have ever gone that high. But its never very cold here either so maybe it varies with the weather
Old Mar 9, 2005 | 05:47 PM
allmotor dc4's Avatar
Default Re: HELP!! MY ACCORD IS CRAZY!!!!!!!! (JDM.Accord)
i live in massachusetts and ive never even seen my cars start up at 2500 last winter there was several days it was BELOW zero in the morning and even then it only revved to about 2200 for a quick second and then dropped to 2000 for a while before descending as usual...
Old Mar 10, 2005 | 03:36 AM
Default Re: HELP!! MY ACCORD IS CRAZY!!!!!!!! (allmotor dc4)
What kind of stupid advice is this? The idle of a car wil not bounce between 1500 and 2500 to warm up. Also, i can you keyboard techs know it's the thermostat without even seeing the car?
Nakyama, if the shop says it's a bad o2 sensor. THen it could be. A couple of tests would be able to tell you that quite easily.
fs
Old Mar 10, 2005 | 05:46 AM
notoriousB's Avatar
Default Re: HELP!! MY ACCORD IS CRAZY!!!!!!!! (filthy_shovel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by filthy_shovel &raquo;</TD></TR><TR><TD CLASS="quote">What kind of stupid advice is this? The idle of a car wil not bounce between 1500 and 2500 to warm up. Also, i can you keyboard techs know it's the thermostat without even seeing the car?
AGREED. your accord should never rev over 2k RPMS, even DEAD COLD.
I personally think it *may* be your IACV. You might want to take it off and clean it out if you are hands-on at all. I had a similar thing happen after a motor swap and it was the IACV causing the idle fluctuation.
Old Mar 10, 2005 | 09:50 AM
Hondaman56's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by filthy_shovel &raquo;</TD></TR><TR><TD CLASS="quote"> can you keyboard techs know it's the thermostat without even seeing the car?
fs</TD></TR></TABLE>
Because mine did this same thing for two years before I discovered that it was the god damn thermostat thats how. Its called EXPERIENCE, got some?
Old Mar 10, 2005 | 09:56 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondaman56 &raquo;</TD></TR><TR><TD CLASS="quote">
Because mine did this same thing for two years before I discovered that it was the god damn thermostat thats how. Its called EXPERIENCE, got some?</TD></TR></TABLE>
Just a bit. I was a tech for 5 years in a honda dealership and still am ASE certified.
fs
Old Mar 10, 2005 | 09:59 AM
NBPcivic07's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotor dc4 &raquo;</TD></TR><TR><TD CLASS="quote">i live in massachusetts and ive never even seen my cars start up at 2500 last winter there was several days it was BELOW zero in the morning and even then it only revved to about 2200 for a quick second and then dropped to 2000 for a while before descending as usual...</TD></TR></TABLE>whats up man i live in new bedford where exacts are u
Old Mar 10, 2005 | 10:34 AM
Default Re: HELP!! MY ACCORD IS CRAZY!!!!!!!! (crableg03)
sup mike... i live in the south too... im the kid who used to have that primered teg with carbonfiber spoon lip
Old Mar 10, 2005 | 11:10 AM
notoriousB's Avatar
sup MA peeps, north shore representin'
And to keep on topic I still think it could be the IACV. And I too have first hand experience.
Old Mar 11, 2005 | 07:21 AM
nakyama's Avatar
OKay, Hello everybody and thanks for replying. I am a female. I purchased this car from a guy who was into the fast and the furious. It has the cold air intake and the aftermarket muffler, high performance clutch, short shifter, the whole nine. I think he totally ragged the car. The mechanics replaced the Idle Valve, and now the 02 sensor. SO FAR (2 days now) it hasn't fluctuated like that while idling. I wonder what the thermostat has to do with the problem. I have noticed that it seems like the idle will do that after the AC has been on. It's bizarre. And my fan only works intermittently. By the way, my car does this when its warm or cold. Could be in the morning or after I've been driving it for an hour or so. Doesn't matter. Any more suggestions?
Old Mar 11, 2005 | 07:24 AM
Default Re: (nakyama)
Well, if the symptoms have not repeated yet, i would wait until it does it again to continue your search.
Now do you have a big sound system in there? If so, maybe your idle is fluctuating because of current drain when both your AC is on and playing some tunes.
Sit tight.
fs
Old Mar 11, 2005 | 07:30 AM
nakyama's Avatar
nope, no big sound system. Straight factory beats! I feel like he sold me a lemon I am going to try and sell it. I only paid $7000 for it and every other Accord that year model and body style was going for $10, 000 so maybe that's why it was so cheap.
AND another thing, my side airbag light keeps coming off and on? Could that be a loose fuse? And my lights on the dash that illuminate the AC controls don't light.
I am clueless.
Old Mar 11, 2005 | 07:53 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nakyama &raquo;</TD></TR><TR><TD CLASS="quote">
AND another thing, my side airbag light keeps coming off and on? Could that be a loose fuse?</TD></TR></TABLE>
Air bag lights are a bit tricky to diagnose without proper tooling... That's something your mechanic will have to look at.
I am clueless.</TD></TR></TABLE>
Could be a bunch of things. Did it have an aftermarket deck prior to you buying it? I may well some shaffed or crossed wires somewhere.
What does your mechanic say?
foxboysracing
Nov 17, 2015 07:56 PM
And tram
Jul 21, 2013 07:09 PM
OpTiMo MoToR
May 19, 2005 08:14 AM
