obd1 distibuter change/ conversion please help easy
Old Mar 8, 2005 | 08:32 PM
davidcrx89's Avatar
Default obd1 distibuter change/ conversion please help easy
when i convert my b16 in my crx to obd1 do i need the distributer also???
thanks
Old Mar 8, 2005 | 08:34 PM
Malgerus's Avatar
Default Re: obd1 distibuter change/ conversion please help easy (davidcrx89)
Yes
Old Mar 8, 2005 | 08:46 PM
Deetz's Avatar
Crazy Honda Guy
I did it on my crx. You will need:
-b series obd1 distributor
-obd1 ecu
- harness conversion
- 4 wire heated o2 sensor
*optional- change injectors and rewire, removing injector harness
Old Mar 9, 2005 | 08:41 PM
davidcrx89's Avatar
Default Re: (Deetz)
so the 4 wire heated o2 sensor would that come from a 95 delsol? and what would i do with the second o2? and does any one know where the info would be found to run the wires to the conversion harness? and what would i get the obd1 distributer from?
Thanks Alot!!!!!!!!!!
Old Mar 9, 2005 | 08:55 PM
eda6's Avatar
Default Re: (davidcrx89)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davidcrx89 &raquo;</TD></TR><TR><TD CLASS="quote">so the 4 wire heated o2 sensor would that come from a 95 delsol?</TD></TR></TABLE>
any 92-95 honda/acura.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davidcrx89 &raquo;</TD></TR><TR><TD CLASS="quote">and what would i do with the second o2?</TD></TR></TABLE>
I'm using a header from a 95 delsol, so the bung is in the collector.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davidcrx89 &raquo;</TD></TR><TR><TD CLASS="quote">and does any one know where the info would be found to run the wires to the conversion harness?</TD></TR></TABLE>
If you buy from blown90hatch you'll get detailed instructions with the harness.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davidcrx89 &raquo;</TD></TR><TR><TD CLASS="quote">and what would i get the obd1 distributer from?</TD></TR></TABLE>
any obd1 b-series vtec motor.
Old Mar 9, 2005 | 09:08 PM
Blown90hatcH's Avatar
Default Re: (eda6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">
any obd1 b-series vtec motor. </TD></TR></TABLE>
What he said. + full tech support so you won't need threads like this one.
Old Mar 10, 2005 | 07:53 PM
davidcrx89's Avatar
Default Re: (Blown90hatcH)
i have the harness made but im getting no spark obviously because of the distributer difference but i was told that you can rewire the obd0 distributer to work. Also what is the difference in the two??
Old Mar 11, 2005 | 01:25 PM
davidcrx89's Avatar
can you use anyobd1 distributer or does it have to be dohc
Old Mar 11, 2005 | 01:36 PM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davidcrx89 &raquo;</TD></TR><TR><TD CLASS="quote">when i convert my b16 in my crx to obd1 do i need the distributer also???
thanks</TD></TR></TABLE>
Depends on the ecu your running but for majority of ecu's out there you will need to convert..
Old Mar 12, 2005 | 07:32 PM
davidcrx89's Avatar
Default Re: obd1 distibuter change/ conversion please help easy (tgreaves)
it is a PR3 ECU and i'm going to convert so now does anyone now how to repin them?
Old Mar 14, 2005 | 06:46 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davidcrx89 &raquo;</TD></TR><TR><TD CLASS="quote">it is a PR3 ECU and i'm going to convert so now does anyone now how to repin them?</TD></TR></TABLE>
If your using a obd1 pr3 ecu and you want to convert the rest of your stuff over to obd1 then im not sure what you want to repin, you going to need an obd1 dizzy and make a conversion plug for obd0-obd1 dizzy and ecu plug..
Old Mar 14, 2005 | 07:38 AM
Where did you buy the harness from? Have you contacted them? They are all setup differently in regards to matching colors or functions.
dem0nk1d
Aug 8, 2007 02:17 PM
vw eater
Feb 4, 2007 09:47 PM
BoostedEgHatchFl
10
Jan 30, 2006 05:48 AM
mrx
Mar 12, 2005 01:06 PM
EVOCELICA
Jul 9, 2004 01:10 PM
