What intake and TB to run on a 2020cc?
Old Mar 8, 2005 | 07:45 PM
sheepey's Avatar
Default What intake mani and TB to run on a 2020cc?
ok Heres my question
I need to know what would be a good mani to run and tb? that would give me teak hp. Also i know ITBS would be the best but i cant afford that at the moment cuase of the damn motor bill. Thanks guys.
Here are my specs
B16 block bored to 85mm 11.5 compression
LS crank and ls eagle rods
Port Flow B16 head work with Buddy Club 4s
AEM EMS
Old Mar 8, 2005 | 08:08 PM
sheepey's Avatar
can anyone help? I dont want to make the wrong choice
Old Mar 8, 2005 | 08:37 PM
2k.civic.si's Avatar
Default Re: (sheepeg3)
aebs intake manifold str 68-70mm throttle body
Old Mar 9, 2005 | 08:14 AM
sheepey's Avatar
yeah thats what i was leaning too..
Old Mar 9, 2005 | 10:22 AM
JerseySiPOS's Avatar
im staying with my AEBS manifold and bored ITR TB 70-65mm.
85X89 gsr block with 12.5 CP pistons and eagle rods
ported b16 head with ferrea .5 over valves (5 angle)
I might be using BC 4s too.
Old Mar 9, 2005 | 10:29 AM
HondaIntegraR's Avatar
Default Re: (JerseySiPOS)
what setup would you guys reccomend if it was a gsr head instead?
Old Mar 9, 2005 | 10:54 AM
Bradstard's Avatar
Default Re: What intake mani and TB to run on a 2020cc? (sheepeg3)
I've got a very similair setup to yours and I'm running a JG IM and RPM Service 72mm TB.
Old Mar 9, 2005 | 03:46 PM
The Specialist's Avatar
Default Re:
Hey Fat Bradstard how well does the JG IM work better then the type r IM?
Old Mar 9, 2005 | 03:48 PM
sheepey's Avatar
imma go with JG IM i think
Old Mar 9, 2005 | 04:30 PM
Bradstard's Avatar
Default Re: Re: (Racer X.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racer X. &raquo;</TD></TR><TR><TD CLASS="quote">Hey Fat Bradstard how well does the JG IM work better then the type r IM?</TD></TR></TABLE>
I never did a dyno comparison between the two. When I built the motor I also changed out the IM.
Old Mar 9, 2005 | 05:09 PM
Mike@K-Tuned's Avatar
Had a simple question about your setup. How are you using an LS crank and LS Eagle rods in a B16 motor? I thought that the stroke with the LS crank and rods was too long and would have the piston sticking right out of the top of the B16 block? Do you have a deck plate or something? Please let me know what I'm missing here. I've seen and put together a fair number of engine combos but never heard of one like you describe. Sounds like a really nice build though, get back to me.
Old Mar 9, 2005 | 06:42 PM
sheepey's Avatar
Its a kit sold by tech43 . He is doing the build as well. He raises the wrist pin on the piston to make it work. If you search "tech43" u will be able to find this.
Old Mar 10, 2005 | 08:36 PM
Thanks for getting back to me. I'll check it out.
advaneh3
11
Mar 19, 2009 01:44 PM
pootie.teng
12
Apr 30, 2007 10:34 AM
baby type r
Oct 4, 2006 06:41 AM
HGL1668
11
Aug 18, 2006 04:57 PM
