13:1 piston clearance??? all motor build???
Old Mar 8, 2005 | 05:12 PM
slodel's Avatar
Default 13:1 piston clearance??? all motor build???
I am building an all motor honda again, but i am going quite a bit higher in the compression area. I am not to wise in the piston clearance. I am purchasing 13:1 pistons and want to know what to do about valve clearance and whta rods to use for my build?? here is what i am using. Can someone enlighten me?? Thanks
b16 head
ls crank
b18b block
13:1 pistons
RODS???
INTAKE MANIFOLD??
THANKS GUYS
Old Mar 8, 2005 | 06:15 PM
v-6 hatch's Avatar
Default Re: 13:1 piston clearance??? all motor build??? (4doorhybrid)
intake manifold i'd say aebs or type r can't go wrong with an r manifold
Old Mar 8, 2005 | 06:36 PM
scUba-stEve's Avatar
i think the piston to valve clearance would have to do with the valve relief cuts in the pistons and the lift/duration of the cams you're going to be using...i dont think the rods have anything to do with it...and the best way to check is to clay the motor.
and as for the manifold...the type r manifold would be good enough...just port match it to your head.
Old Mar 8, 2005 | 07:59 PM
Nisif's Avatar
As far as your rods go, how high is the motor going to be reved to? A lot of people will use the stock ls rods (definetly get arp rod bolts tho) or you can step up to eagle rods, that's what I'm running and motor is built to rev to 9.
Flexin5
Sep 19, 2006 11:16 AM
sprayedlude93
Jan 6, 2006 12:56 PM
slodel
Mar 8, 2005 11:59 AM
Whatever
May 3, 2004 07:07 PM
smnowell
Oct 11, 2002 01:10 PM
