GSR BB and MC install?
Old Mar 8, 2005 | 05:08 PM
AccordVtec's Avatar
Default GSR BB and MC install?
Hey Guys,
I just got My 2000 JDM GSR Brake Booster and Master Cylinder in my 1993 cx h/b
Can anyone post pics on there setup between the brake lines and the master cylinder. I noticed on my eg there is very little space for a fitting between the Shock towers and the Master cylinder.
Any help would be appreciated.
Thanks,
MIke
Old Mar 8, 2005 | 05:32 PM
AccordVtec's Avatar
Default Re: GSR BB and MC install? (AccordVtec)
Come one guys, I need a pic to boost my moral so that I know it can be done.
Thanks
Old Mar 9, 2005 | 05:39 AM
AccordVtec's Avatar
bump
Old Mar 9, 2005 | 05:41 AM
pdiggitydogg's Avatar
See this: https://honda-tech.com/zerothread?id=818263
Old Mar 9, 2005 | 03:16 PM
AccordVtec's Avatar
The GSR master cylinder has both of it's fittings in line with eachother. That Type R install was different.
Anyone else?
Old Mar 9, 2005 | 05:32 PM
93civicsedan's Avatar
i think for the gsr you have to bend and reflare some lines. its easier just to get the booster amd MC from a teg RS since they bolt right in.
Old Mar 10, 2005 | 10:21 AM
AccordVtec's Avatar
Default Re: GSR BB and MC install? (93civicsedan)
Does anyone know if I can use a 94-up Teg RS master cylinder on a GSR Brake Booster.
Old Mar 10, 2005 | 11:16 AM
yes thats the easiest way to go. i have that setup in my 93 4 door. just make sure they are RS, cause if you mix with gsr or ls your brakes will lock up. The RS MC is stamped 15/16" and the booster looks just like your stock one but it has the mounting screws on opposite ends.
little2fast4u
13
May 10, 2010 12:31 PM
BoOsTiN Dc2
Feb 25, 2005 06:47 AM
JKim0901
May 30, 2004 08:27 PM
tyronebiggums
Jan 29, 2004 11:34 AM
Jason kiDD
Apr 30, 2002 05:14 AM
