Is there a proper way to roll fenders?????
Old Mar 8, 2005 | 12:51 PM
Halo's Avatar
Default Is there a proper way to roll fenders?????
My friend basically gave me a set of 16x9 jdm guiiles...These are way too wide for my 2004 ep3..Can anyone suggest the best way to roll the fenders out..I have done the baseball bat thing before but I need a more extreme roll..
Modified by Halo at 7:58 AM 3/9/2005
Old Mar 8, 2005 | 01:07 PM
Kookz's Avatar
Resident Vagabond
Default Re: Is there a proper way to roll fenders????? (Halo)
Old Mar 8, 2005 | 01:15 PM
turbo90crx's Avatar
Default Re: Is there a proper way to roll fenders????? (Kookz)
where do u get one of those fancy tools?
Old Mar 8, 2005 | 01:52 PM
1bar's Avatar
damn thats cool
Old Mar 8, 2005 | 01:55 PM
92HB_HB's Avatar
not to be a bad guy, but u probably wouldn't want to roll ur fenders ..
in my experience, if u roll ur fenders, you may crack the paint that's on the fenders, although this may not be a concern for u in the short run, in the long run, the cracked paint and exposed metal will cause the fender to rust and you'll have a hard time tackling that problem..
I did it to my 94 Legend a few yrs ago and deeply regret it because now the side that I tried to roll is has rusted and the rust is spreading.. I didnt' bother w/ the other side and its perfectly fine today, no rust at all..
Looking good right now, may not be totally worth rust and headaches in the future..
Old Mar 8, 2005 | 04:17 PM
Halo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kookz &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
I have seen that tool but don't feel like shelling out $300 bucks for a one time job
Old Mar 8, 2005 | 04:42 PM
hayabusa160's Avatar
you can rent it
Old Mar 8, 2005 | 04:47 PM
CRXDrew's Avatar
I was gonna say don't do it because salt will get trapped there... but you live in Cali so nevermind.
Where do u get one of those things from? Looks cool.
Old Mar 8, 2005 | 05:06 PM
SJcivic's Avatar
Default Re: (CRXDrew)
eastwood sells those. But you have to be mighty carful (i hear anyways) or the paint will crack. Some have even used heat guns to make the paint 'flexable' then roll the fenders. Anyone else got any imput here?
Rich
Old Mar 8, 2005 | 09:43 PM
l2Y4N's Avatar
there was a thread in the type r forum a while back of a guy who used the tool pictured. he said there was not paint cracking. i have used the good ol' baseball bat method with bad results as mentioned.
Old Mar 8, 2005 | 09:48 PM
Default Re: Is there a proper way to roll fenders????? (integraTracer)
you should heat the paint before you roll to prevent the chance of cracking the paint.
i kno alot of 240 guys who do it to clear wheels
Old Mar 9, 2005 | 04:41 AM
Turbo-charged's Avatar
Default Re: Is there a proper way to roll fenders????? (hayabusa160)
my friend has one of those fender rollers at his shop.....no paint cracking. i didnt give 2 ***** about my civic and used a wooden baseball bat and cracked the paint....its getting painted once i get some 10 second pass's on it so i wasnt too worried about it. that tool is where its at though.
Old Mar 9, 2005 | 07:47 AM
Dee's Avatar
Dee
Default Re: Is there a proper way to roll fenders????? (Turbo-charged)
We always use a heatgun before rolling the fenders so the paint does not crack. You can get that tool off of Yahoo Japan auctions really cheap.
Old Mar 9, 2005 | 08:42 AM
JOEY F.'s Avatar
Default Re: Is there a proper way to roll fenders????? (Dee)
I rolled my fenders with a pipe. Sure I got some cracked paint and what not but I painted it again with a spray can of the same color. (No one sees the inner lip anyway so it didnt have to be as perfect as my outside paint.) After 2 years no rust or any problems. Just make sure you seal the metal that was exposed from the rolling process w/ paint. Its not that big a deal.
Old Mar 9, 2005 | 08:46 AM
getnasty's Avatar
Default Re: Is there a proper way to roll fenders????? (JOEY F.)
I do it this way. the lip is just a piece of thin metal. take a pair of metal tin snips, cut the lip in about 4 places(equal) length apart. take a pair of pliers or metel tongs, and fold up. just my way. not perfect. never had paint crack.
Old Mar 9, 2005 | 04:05 PM
JDogg's Avatar
Default Re: Is there a proper way to roll fenders????? (bottle fed)
baseball bat always worked good for me
Old Mar 9, 2005 | 06:25 PM
onePOINTsix's Avatar
Default Re: Is there a proper way to roll fenders????? (JDogg)
i think Dropspeed on here did a write up on it... i dont remember tho, my friend just bought his old car with rolled rear fenders and they are hold up great
Old Mar 9, 2005 | 08:50 PM
RedlinedVTEC's Avatar
Default Re: Is there a proper way to roll fenders????? (onePOINTsix)
You can rent one for $75 from http://www.fenderroller.com/, and they even say on the site to use a heat gun, should work just fine, I plan on renting one with my roommate, split the cost.
Old Mar 10, 2005 | 02:29 AM
tONE.steR's Avatar
* B A N N E D *
Default Re: Is there a proper way to roll fenders????? (RedlinedVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedlinedVTEC &raquo;</TD></TR><TR><TD CLASS="quote">You can rent one for $75 from http://www.fenderroller.com/, and they even say on the site to use a heat gun, should work just fine, I plan on renting one with my roommate, split the cost.</TD></TR></TABLE>
Cheaper to take it to a shop to get rolled.
Old Mar 10, 2005 | 07:25 AM
1fastVX's Avatar
Default Re: Is there a proper way to roll fenders????? (Vita-Soy)
Guys I think tirerack.com used to rent them for no cost. You might want to check with them to see if they still do that.
John
Old Mar 10, 2005 | 08:54 AM
TurboJesse
Guest
Posts: n/a
Default Re: Is there a proper way to roll fenders????? (1fastVX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1fastVX &raquo;</TD></TR><TR><TD CLASS="quote">Guys I think tirerack.com used to rent them for no cost. You might want to check with them to see if they still do that.
John</TD></TR></TABLE>
last i heard the wait is very long..
Old Mar 10, 2005 | 09:18 AM
AP-Signworks1's Avatar
That and you have to pay them a $475 deposit, so $550 up front and then they refund you after the return. A lot of money to have floating out there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vita-Soy &raquo;</TD></TR><TR><TD CLASS="quote">
Cheaper to take it to a shop to get rolled.</TD></TR></TABLE>
Old Mar 10, 2005 | 09:23 AM
tONE.steR's Avatar
* B A N N E D *
And if there is any paint damage they are responsible for the damage.
Old Mar 10, 2005 | 10:11 AM
gophaster's Avatar
I've also used the baseball bat method many times with no problems. I use a wooden bat...jack up the car, insert bat on top of tire at angle, lower car carefully onto bat, roll slowly, has worked like a charm for me. The trick is, that if any paint comes of, sand the area and paint right away (this will be inside the fender so it cannot be seen, this is just to keep it from starting to rust) One car, my 90 Integra 4 dr was rolled like this back in 93...12 years later no probs at all.
Old Mar 10, 2005 | 10:26 PM
Wideopentuning's Avatar
Default Re: (gophaster)
I rent my roller out for $50 a week.
h23ajdmlude
Jan 18, 2010 10:03 PM
scarsofterror
Oct 29, 2009 12:18 PM
Xerxes3333
Apr 6, 2004 08:27 PM
sohc00
Apr 3, 2004 06:06 AM
Mr.SpiLLz
Mar 21, 2003 12:47 PM
