fluidyne install
Old Mar 8, 2005 | 12:24 PM
accordlove's Avatar
Default fluidyne install
i just wanted to share. when i put this in i ran into a few problems, the first was the i have a auto and the radiator was for a manual. second the stock fan did not bolt up. i had to add a tranny cooler, since the old one was part of the raditor. for the fan i had to put bolts in the holes were the fan should bolt up. then i put holes in the fan and put zip ties in to hold it up. this is only till i can get a fan. i plain on putting on a turbo so this just get some work out of the way. [img] http://www.we-todd-did-racing.com/we...D.jpg[/img] [IMG] [img] http://www.we-todd-did-racing.com/we...D.jpg[/img] here are some more pics i still have to finish painting the trunk.
Old Mar 8, 2005 | 07:20 PM
brads94accord's Avatar
cool stuff i was thinking of getting a koyo for mine and some slim fans. dude the harness setup you have going on is not very safe...for one you are running stock seats...why not just run the stock seatbelts...the designers weren't retarded when they designed them. they work just fine for anything you will be doing in an accord.
Old Mar 8, 2005 | 07:52 PM
accordselux's Avatar
Me Gusta History
Default Re: fluidyne install (accordlove)
I'm diggin the radiator and the stripped accord, but yes, don't change out the stock seatbelts, theyre a lot safer than you think...those things will get you killed.
Old Mar 8, 2005 | 08:37 PM
accordlove's Avatar
Default Re: fluidyne install (accordselux)
the harness are dot approved. i know other people that have used them for years.
Old Mar 8, 2005 | 11:51 PM
ridexstraight's Avatar
it may be dot approved straps but u have them mounted wrong, the shoulder strap should b at least shoulders height or a lil higher, if u wreck it could break or back wit them mounted so low
Old Mar 9, 2005 | 02:39 AM
accordlove's Avatar
Default Re: fluidyne install (ridexstraight)
this is another way the instructions said you can mount them.
Old Mar 9, 2005 | 04:35 AM
iakona's Avatar
waaay off topic, but yes, you can mount them at a 45-degree angle. you just cannot mount them behind the seats on the floor.
and good job on the radiator install! the fans are a pain. i used a couple of derale fans for mine. you should have let us know though, i have a B&M trans cooler you could have used.
Old Mar 9, 2005 | 07:13 AM
accordlove's Avatar
Default Re: (iakona)
finally someone that knows what they are talking about. thanks for the props. i was in a hurry to get the radiator in, the stock one was leaking. the cooler was 30 bucks at autozone. sorry there are no pics i took them off to upload a video of teglove2 turbo ls. i will put them back up in a couple of days.
Bee16hatch
Apr 28, 2018 10:22 PM
delsol7
17
Nov 17, 2007 12:24 PM
GSRNetics
Apr 28, 2006 03:48 PM
AVATAR
Apr 21, 2004 11:57 AM
4doorH22
May 3, 2002 06:11 PM
