fuel pump
Old Mar 8, 2005 | 11:44 AM
shawn_crx's Avatar
Default fuel pump
how do you take the fuel pump out?
I got the cover off. Somehow the lid wrong move. Is there a specail way to take it out?
Old Mar 8, 2005 | 11:55 AM
HatchBox's Avatar
Skoobie no more...
Default Re: fuel pump (shawn_crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shawn_crx &raquo;</TD></TR><TR><TD CLASS="quote">how do you take the fuel pump out?
I got the cover off. Somehow the lid wrong move. Is there a specail way to take it out?</TD></TR></TABLE>
You must drop the gas tank unfortionally.
There are 2 straps that hold it up and a few lines you must disconnect on the driver side.
Drain the tank and place a jack with a 2X4 on it and jack it up so the wood is against the tank (for support) Then undo the straps half way and unbolt the fuel lines (make sure there all disconnected then drop the tank all the way.
Old Mar 8, 2005 | 12:44 PM
shawn_crx's Avatar
Default Re: fuel pump (HatchBox)
so i have to take the tank out to get the fuel pump out?
I could see the fuel pump in the car.
Old Mar 8, 2005 | 12:48 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shawn_crx &raquo;</TD></TR><TR><TD CLASS="quote">so i have to take the tank out to get the fuel pump out?</TD></TR></TABLE>
Unfortunately, yes. That's the way it has to be done with '88-91 Civics.
Old Mar 8, 2005 | 05:34 PM
HatchBox's Avatar
Skoobie no more...
I could see the fuel pump in the car.</TD></TR></TABLE>
the peice you see is the sending unit, not the fuel pump.
you will see once you drop the tank
Old Mar 8, 2005 | 06:12 PM
shawn_crx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchBox &raquo;</TD></TR><TR><TD CLASS="quote">
you will see once you drop the tank </TD></TR></TABLE>
thank you
Old Mar 8, 2005 | 06:30 PM
HatchBox's Avatar
Skoobie no more...
No problem, Have fun
Old Mar 8, 2005 | 06:32 PM
honda06si's Avatar
is this the same for the crx? that sux casue im puttin a bigger one in pretty soon
Old Mar 8, 2005 | 06:35 PM
HatchBox's Avatar
Skoobie no more...
Default Re: fuel pump (honda90si)
i know the all 88-91's you have to drop the tank, but im unsure about the earlier ones.
thedudefromjerz
Nov 5, 2007 10:02 AM
B Series JuNky
Aug 6, 2007 10:20 PM
accordredliner
Feb 26, 2006 02:41 AM
faSHOwidIT
Apr 7, 2005 03:36 PM
bossman032
18
Jun 1, 2004 08:16 PM
