FS D16 T3 Turbo
Sup im selling my D series turbo kit due to getting a new car soon.
- Garrett T3 turbo (60 trim compressor and .63 a/r exhaust side, internally wastegated)
- custom cast iron manifold, treated and coated to withstand extreme temp.s
- custom 2.5" downpipe with 2 oxygen sensor bungs and flex pipe (also coated)
- 1g DSM blow-off valve w/ flange, already welded and bolted to the piping
- intercooler piping, coated with a hi-temp resistant finish.
- all necessary couplers and clamps
- oil tee
- DSM blue top injectors.
- Home Made Boost Controller
$600 plus shipping OBO.
There's a small bolt in the outer housing where the downpipe meets, which can be drilled out. Otherwise, the turbo is in perfect condition. Absolutely no shaft play, and has very low miles (only a couple thousand). The downpipe's a bit scuffed by the flex pipe, and two bolt holes have been modified to fit the housing better, washers should be used when bolting up (simple). Otherwise, everything's great.
NOT EVERYTHING IN PICTURES ARE INCLUDED!
INTERCOOLER NOT INCLUDED*
- oil tee
Vp Special K
Nov 29, 2009 06:02 PM
RedStarGsr
May 6, 2004 01:14 PM
integraracer94
Apr 9, 2003 10:55 AM
