D15b2 to D16a6 Swap
Old Mar 8, 2005 | 11:13 AM
CHAPY's Avatar
Default D15b2 to D16a6 Swap
Hi everybody.
I hope you will understand what im asking about, im from denmark and my english is not the best.
Im doing a D15b2 to D16a6 swap. I got allot of help from this site: http://www.angelfire.com/d20/h....html
But... The Resistor Box.... can i use from a Honda concerto from 92?
There is no Flywheel on the D16a6, so can i use it from my D15b2? And what clutch shall i order then? For a D15 or D16? I hope you guys can help me. thanx!
Modified by CHAPY at 12:50 PM 3/8/2005
Modified by CHAPY at 1:03 PM 3/8/2005
Old Mar 8, 2005 | 11:50 AM
Aragorn's Avatar
Default Re: D15b2 to D16a6 Swap (CHAPY)
Here's the link... you can also try searching for MPFI in this forum.
https://honda-tech.com/zerothread?id=639552
"The Resistor Box.... can i use from a Honda concerto from 92?"
Don't know for sure, but if that's an OBD0 car and uses a resistor box, then the answer is probably yes.
"There is no Flywheel on the D16a6, so can i use it from my D15b2? And what clutch shall i order then? For a D15 or D16? "
Yes to the flywheel and use the clutch for your tranny.
Modified by CHAPY at 12:44 PM 3/8/2005[/QUOTE]
Old Mar 8, 2005 | 12:08 PM
CHAPY's Avatar
Default Re: D15b2 to D16a6 Swap (Aragorn)
Ok, that sounds good!
Is there different PM6 ECU, or are they exactly the same when the nr is PM6?
Im thinking about Lambda sensor!
Old Mar 9, 2005 | 04:50 PM
Aragorn's Avatar
Sometimes there are differences between USDM, JDM, & EDM ECU's. I'm not suer in the case of a PM6. This link should be able to shed some light on that:
http://www.pgmfi.org/
Functional they should all be the same and use the same O2 (Lambda) sensor.
McGruber
13
Nov 30, 2009 07:33 AM
Aynatix
Apr 13, 2007 03:06 PM
crxpwr1
Jun 13, 2006 02:32 PM
HondaRacer18
Apr 5, 2006 11:22 AM
serious
May 30, 2002 06:36 PM
