RECARO JDM type R seats... passenger seats is higher ???
Old Mar 8, 2005 | 08:15 AM
yellowturbo's Avatar
Default RECARO JDM type R seats... passenger seats is higher ???
Take a look at the picture, the passenger seat is 1.5 inch higher than my driver seats ?? what could explain this problem ? Is there different height ?
I bought the two seat at the same time but used from a guy...
Anyone could help me please ?
Old Mar 8, 2005 | 08:21 AM
esponet's Avatar
go check to see if your mounts are different.
Del Sol SiR's Avatar
The driver's seat looks reclined back more...
Old Mar 8, 2005 | 08:25 AM
bananaek's Avatar
Default Re: (DELSOLEMITE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DELSOLEMITE &raquo;</TD></TR><TR><TD CLASS="quote">The driver's seat looks reclined back more...</TD></TR></TABLE>
it happens to me sometimes
Old Mar 8, 2005 | 08:37 AM
cre18's Avatar
Default Re: (DELUSIONEK4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DELUSIONEK4 &raquo;</TD></TR><TR><TD CLASS="quote">
it happens to me sometimes </TD></TR></TABLE>
go check your seat rails
Old Mar 8, 2005 | 08:40 AM
june's Avatar
Default Re: (cre18)
The drivers seat is reclined.
Old Mar 8, 2005 | 08:43 AM
tyflip2's Avatar
Default Re: (june)
yeah i bet one has a civic rail and one has an integra rail. when you bolted them in did all 4 holes line up on both seats?
Old Mar 8, 2005 | 08:45 AM
IntegraBoy04's Avatar
Default Re: (tyflip2)
The driver's seat is reclined. Other than that, it looks the same to me.
Old Mar 8, 2005 | 09:03 AM
the 2 seats are at the same inclinaison !
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tyflip2 &raquo;</TD></TR><TR><TD CLASS="quote">yeah i bet one has a civic rail and one has an integra rail. when you bolted them in did all 4 holes line up on both seats?</TD></TR></TABLE>
on the driver seat the 4 bolts were bolt-on but on the passenger seat just 3 bolts were ok... and I have the impression that im not sitting really straight forward in it...
Old Mar 8, 2005 | 09:05 AM
yeah and the rails look a bit different...
Old Mar 8, 2005 | 09:14 AM
bump
Old Mar 8, 2005 | 09:18 AM
B18ls*RAYON's Avatar
Default Re: (yellowturbo)
Try checking the rails. You can have a shop fab your OEM rails and sliders, then bolt your seats to those. Just a thought.
Old Mar 8, 2005 | 09:24 AM
singhg83's Avatar
you have an extension cord on your car.
Old Mar 8, 2005 | 10:30 AM
Default Re: (singhg83)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by singhg83 &raquo;</TD></TR><TR><TD CLASS="quote">you have an extension cord on your car. </TD></TR></TABLE>
yeah... my car is in my garage...
Old Mar 8, 2005 | 10:44 AM
cubanSiR's Avatar
* B A N N E D *
check it...the way you can tell that the passenger seat has integra rails is because only 3 bolts match up...if they were civic rails...all for would bolt directly in.
Old Mar 8, 2005 | 11:01 AM
mmmh ok and ift its the case, that my passenger have integra rails..., what I can do ?? return it ?? or I could get the rails from my stock seat ?
Old Mar 8, 2005 | 11:40 AM
fullraceacura's Avatar
also the rails from 4dr integras sit higher than 2dr and civic
Old Mar 8, 2005 | 11:42 AM
juicy.fn's Avatar
Default Re: (itr#xxxxlives)
its either the rails or the driver seat is reclined more. or your eyes are playin games wid you
Old Mar 8, 2005 | 05:27 PM
Hater's Avatar
Default Re: (juicyfn)
Judging by the picture, I'd say you need new windshield wipers.
If the rails are different, and only 3 of the holes mated up, it sounds like you've obviously figured out the problem.
Old Mar 8, 2005 | 05:36 PM
mikehawkBUiLT's Avatar
Default Re: (Hater)
those seats are hella comfortable. i loved them when they were in my ej as should you
Old Mar 8, 2005 | 06:06 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juicyfn &raquo;</TD></TR><TR><TD CLASS="quote">its either the rails or the driver seat is reclined more. or your eyes are playin games wid you </TD></TR></TABLE>
nope the 2 seats are reclined at the same place... and I have a lot more space over my head in the driver seat...
anyway now im sure that I have Integra rails on the seat... could I use the stock rail from my old seat ??
Old Mar 8, 2005 | 06:20 PM
unknown0001's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowturbo &raquo;</TD></TR><TR><TD CLASS="quote">anyway now im sure that I have Integra rails on the seat... could I use the stock rail from my old seat ?? </TD></TR></TABLE>
I have a great idea...instead of bumping this thread...go take the seat rails off and try your stock rails on it
Old Mar 8, 2005 | 06:45 PM
hasback*'s Avatar
F*CK THIEVES!
Old Mar 8, 2005 | 10:58 PM
BlueIntegraBoy's Avatar
Default Re: RECARO JDM type R seats... passenger seats is higher ??? (yellowturbo)
I believe I had the same problem as you. When I bought black JDM ITR Recaros for my GSR, the driver seat bolted right in. The passenger side, however, only three holes lined up. Well technically, one hole was a little sideways and one hole needed to be bent down. I was able to align one of the front holes to fit the screw into the hole. The rear hole needed to be bent down, so I took a hammer. I got all four bolts in. The passenger seat seemed to sit slightly higher than the driver seat. I didn't bother me. But I wonder what kind of rails I had since they were removed from the same car.
Old Mar 8, 2005 | 11:04 PM
areyoujealous's Avatar
Default Re: RECARO JDM type R seats... passenger seats is higher ??? (BlueIntegraBoy)
easy
drivers side is civic rail
passenger side is integra rail
yes your stock rails should work with some elbow grease. Mate them to the sliders under the pass seat
