Suspension & Brakes Theory, alignment, spring rates....
Unit Conversion
Old Mar 8, 2005 | 07:32 AM
veggiemaster's Avatar
Default Unit Conversion
Ive noticed a lot of people interchanging kg/mm and lb/in. Which are technically 2 different things. So to convert, multiply your kg/mm by 56 to get your equivalent lb/in
IE. 10kg/mm =~ 560 lb/in
or 600 lb/in =~ 10.7 kg/mm
now, dont get this confused with torque, which is measured in ft lbs or in lbs and converted into Nm (newton meter) that conversion is approx. 1 ft lb =~ 1.3558 Nm
hope it helps.
Old Mar 8, 2005 | 11:21 AM
00R101's Avatar
Default Re: Unit Conversion (veggiemaster)
What's kinda interesting here is what happens to spring rates on the moon. The Kg/mm numbers will stay the same but the lb/in numbers will be approximately 1/6th of their original value.
Old Mar 8, 2005 | 12:22 PM
Tyson's Avatar
eibach uses lbs/inch or N/mm which has a x5.71 conversion factor.
1 N/mm = 5.71 lbs/inch
44 N/mm ~ 250 lbs/inch
i havent noticed anyone mixing up torque with spring rate yet myself...
Old Mar 8, 2005 | 12:37 PM
Default Re: Unit Conversion (Tyson)
ive seen people confuse a foot pound (torque) with pound/feet. so yes. and the best way IMHO is how eibach does it, Newton/ Meter (or mm). Makes much more sense.
well, and the reason for the moon difference, is that Kg is a unit of MASS not weight, like a pound or newton.
Old Mar 8, 2005 | 01:44 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by veggiemaster &raquo;</TD></TR><TR><TD CLASS="quote">ive seen people confuse a foot pound (torque) with pound/feet.</TD></TR></TABLE>
Pound-feet is actually the correct term for a unit of torque. Foot-pounds, commonly seen on many torque wrenches, is actually wrong. Whoever labels my tools must have failed out of high-school physics.
Old Mar 8, 2005 | 01:52 PM
Tyson's Avatar
Default Re: Unit Conversion (Targa250R)
um... lb*ft = ft*lb
basically my point is theres nothing technically wrong with either. whatever convention you want to follow...
Old Mar 8, 2005 | 01:57 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">um... lb*ft = ft*lb</TD></TR></TABLE>
Mathematically, you'd be correct by the reflexive property of multiplication - but not exactly in this case.
http://www.findarticles.com/p/...58018
Old Mar 8, 2005 | 02:00 PM
Tyson's Avatar
theres a nit somewhere here you can pick....
NIT! -----&gt; .
Old Mar 8, 2005 | 02:02 PM
Targa250R's Avatar
be professional
I'm taking up a collection
non-VTEC
Suspension & Brakes
12
Apr 2, 2010 01:58 PM
JOHN WAYNE
Suspension & Brakes
Apr 26, 2005 07:04 AM
CXHatchback
11
Feb 5, 2003 07:25 PM
jg
Aug 20, 2002 09:07 AM
JinMTVT
Jun 23, 2001 03:31 PM
