ls/vtec question
Old Mar 8, 2005 | 06:44 AM
burnitup's Avatar
Default ls/vtec question
ok im ganna be using prs pistons and ls rods on my ls vtec. i was wondering wich head gasket i should use with a turbo or if i wanna put a 50 shot on it. i no stock whould make it 11.5.1 what would it be with a 86mm headgasket and would it be safe. sorry im a noob.
thanks NICK
Old Mar 8, 2005 | 08:29 AM
97L-esVeeTeg's Avatar
Default Re: ls/vtec question (burnitup)
uhhh...first thing is this is the all motor forum. Next thing turbo+11.5cr=BOOM. And lastly is it stock bore or is it 86mm?
Old Mar 8, 2005 | 08:56 AM
burnitup's Avatar
Default Re: ls/vtec question (97L-esVeeTeg)
ye i no its an all motor frum but i didnt think itwould matter bc its ganna be allmotor for a wile any way. but its stock bore plus the thicker head gasket would lower the c/r i was wondering what it would be and if it would be safe to use thanks.
NICK
Old Mar 8, 2005 | 09:06 AM
stock bore is 81mm, so I'd imagine that may cause some sealing problems being that you want to use a 86mm HG. If you want to lower comp. get a thicker HG not a larger bore. Stock is .026 so anything thicker than that will yield lower CR
Old Mar 9, 2005 | 06:52 AM
burnitup's Avatar
ya my bad does any one no how much diffent the cr will be the for a thicker headgasget
Old Mar 9, 2005 | 07:02 AM
could you give more info like:
PDH- Dome CC's- Stroke- Bore- Milled?Decked?- High Comp Valves- HG Thickness,etc.
blackcrx16
Apr 26, 2008 12:12 PM
bnut510
Jul 8, 2007 12:02 PM
Jdmsolutions
Jan 2, 2007 08:39 AM
tunedek
Feb 26, 2005 12:01 PM
soulless1
Jul 19, 2003 06:26 AM
