Need Help identifying injectors
Old Mar 8, 2005 | 06:11 AM
Stoich's Avatar
Default Need Help identifying injectors
I got 2 sets of injectors here with harnesses
one set came from a D16z6 the others came from a Crx St
Stoich's Avatar
Default Re: Need Help identifying injectors (Stoich)
one set has grey plugs the other has white plugs
im doing the MPFI swap and need to know which set to use
Old Mar 8, 2005 | 06:31 AM
green91's Avatar
measure the resistance with an ohm meter
Old Mar 8, 2005 | 07:28 AM
eda6's Avatar
Default Re: (green91)
you can use either one. if you use the injectors with gray plugs, don't wire up a resistor box.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by green91 &raquo;</TD></TR><TR><TD CLASS="quote">measure the resistance with an ohm meter</TD></TR></TABLE>
p&h 1-5-2.5 ohms
saturated (gray plugs) 10-13 ohms
Old Mar 8, 2005 | 07:29 AM
Stoich's Avatar
the white plug injector gave me a 02.2 ohm and the grey plug injector gave me a 11.8ohm readout.
Old Mar 8, 2005 | 07:30 AM
Stoich's Avatar
Default Re: (eda6)
thanks man
mike03,95civic
18
May 22, 2008 02:03 PM
949
12
May 12, 2008 07:30 AM
sasinorm01
Nov 5, 2007 08:39 AM
russianswty
Jan 10, 2007 08:32 AM
b16ahybrid
Nov 18, 2003 08:10 PM
