Spary gun question
Old Mar 7, 2005 | 09:53 PM
RCautoworks's Avatar
Default Spray gun question
I figured I would ask here because more poeple with a gun would look, what does a normal gun operate at ( what psi ). Also anything to look out for when buying one, looking at a sata one right now.
Old Mar 8, 2005 | 05:13 AM
WhatThaFrig's Avatar
Default Re: Spary gun question (90blackcrx)
On an HVLP gun I believe the input should be around 40psi. Any gun made by Sata is a good gun,expensive but good. I bought a couple Sharpe Cobalt series and I love them. Good price and a good gun.
Old Mar 8, 2005 | 05:25 AM
kranked91dx's Avatar
I use HLVP Devilbiss unit,
they are precise and able to do almost anything from base coat to clear ( they are not that good for clear but they will do it )
the input pressure is 40 psi, but I have an adjustable regulator on my gun, also don't forget to never shoot anything important without a water catcher inline with your gun, of course no oiler that would be stupid.
Hope this help
Kranked
Old Mar 8, 2005 | 08:48 AM
Default Re: Spary gun question (kranked91dx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kranked91dx &raquo;</TD></TR><TR><TD CLASS="quote">I use HLVP Devilbiss unit,
Hope this help
Kranked</TD></TR></TABLE>
Thanks, see right now I have a 15 gallon compressor which I am trying to determine if it is big enough, I talked to a guy with the same compressor and he said it would be, so I might give it a try.
Old Mar 8, 2005 | 10:12 AM
CRXDrew's Avatar
That guy was me. Worked out great when I sprayed my car. Bump for ya Bob.
Old Mar 8, 2005 | 05:31 PM
quickersol's Avatar
Default Re: (CRXDrew)
i used to use an expensive *** kremlin gun but now use a homo depot version cheapo campbell hautsfield. i swear it works just as well as the kremlin and only cost about $40. a close friend owns smooth customs, one of the top custom painting and air brushing shops in the midwest. he has painted everything from $40k bikes to lambo's to old schools... he does the most incredable work i have ever seen besides cal concepts. he uses the same cheapo $40 gun... sounds crazy but the thing works!
if you want to check out some of what hes doing with an el-cheapo $40 gun look at his ebay auctions for motorcycle sheetmetal:
http://cgi.ebay.com/ebaymotors...38664
Old Mar 8, 2005 | 06:55 PM
CRXDrew's Avatar
I've never had a problem with campbell hausfield products. I used a cheapo no-name gun from Pepboys.
eBay is my recommendation.
Old Mar 9, 2005 | 05:36 AM
B6tPoweredMx3's Avatar
**** there absolutley nothing wrong with the campbell hausfield gun i bought it 2 years ago and have had no problems with it.
Old Mar 9, 2005 | 10:55 AM
Default Re: (B6tPoweredMx3)
I found a good place
http://www.spraygundepot.com
Old Mar 10, 2005 | 07:21 AM
kid-honda's Avatar
I only use sata.
The aveage PSI is around 40 but thta can vary by gun.
Your compressor would be prety small for painting anything bigger then a panel.
Old Mar 10, 2005 | 07:31 AM
Bullet01's Avatar
Default Re: Spary gun question (kid-honda)
I use Sata and Devilbiss guns...depends on what I am spraying is what gun and set-up I will use. Temp and Humidity are things to look at. If you are doing this at home, do it outside, unless your in Cali. you get less dirt and dust from the interior of a garage. Good Luck with your project. BTW a 6H.P.- 33 gallon tank is what i use, 15 sounds kinda small, but if its a small job and not an overall complete job you might be ok.
Old Mar 10, 2005 | 08:01 AM
kid-honda's Avatar
Default Re: Spary gun question (Bullet01)
Tkae air hose and blow all dust out of of garage and then wet floor to keep all dust down if you are not in a booth it works well.
Old Mar 10, 2005 | 08:41 AM
CRXDrew's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kid-honda &raquo;</TD></TR><TR><TD CLASS="quote">Tkae air hose and blow all dust out of of garage and then wet floor to keep all dust down if you are not in a booth it works well.</TD></TR></TABLE>
exactly what i did
Doing outside is a BAD idea.
Old Mar 10, 2005 | 09:18 AM
I already have a set up in my mind, gonna make basically another garage inside my garage, made out of plastic and what not. And I am suppose to be picking up an 80 gallon compressor for free, but not sure how great of shape its in.
Old Mar 10, 2005 | 10:46 AM
kid-honda's Avatar
Yea thats the best method, tape off smaller are with heavy plastic and wet floor.
The 80 gallon would be much better, I wouldnt advise less then 60.
Old Mar 10, 2005 | 11:02 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kid-honda &raquo;</TD></TR><TR><TD CLASS="quote">Yea thats the best method, tape off smaller are with heavy plastic and wet floor.
The 80 gallon would be much better, I wouldnt advise less then 60.</TD></TR></TABLE>
Well hopefully I can get a bigger compressor, hopefully the one I'm getting for free is not rusted out.
The gun I just bought
Anyone know of any good sites or books to pick up, just want to read on painting
Old Mar 10, 2005 | 12:15 PM
kurinto's Avatar
http://www.autobody101.com
If you come and pick up that door from me I can explain a lot to you if you'd like.
Old Mar 10, 2005 | 12:22 PM
Default Re: Spary gun question (kurinto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kurinto &raquo;</TD></TR><TR><TD CLASS="quote">http://www.autobody101.com
If you come and pick up that door from me I can explain a lot to you if you'd like.</TD></TR></TABLE>
Thanks, IM sent
Old Mar 10, 2005 | 06:07 PM
kid-honda's Avatar
What size tip did you get? I use a 1.3 for color/clear.
What are you using for applying primer? gun? roll on? rattle car?
Old Mar 10, 2005 | 08:26 PM
1.4 tip , and I will be using the gun for primer and clear hopefully.
Old Mar 10, 2005 | 08:28 PM
kid-honda's Avatar
It will be a little "light" for a primer.
I would suggest a bigger tip around 2 for good thick primer coats.
Old Mar 10, 2005 | 08:34 PM
Thanks, off hand how much do nozzles run ?
Old Mar 10, 2005 | 08:37 PM
kid-honda's Avatar
Default Re: (90blackcrx)
If I remember right they were around $85 I think? dont quote me on that, i just use seperate guns so i dont forsure know thet individule needle prices but I asked awhile back and I think thats what they said.
Old Mar 10, 2005 | 08:39 PM
Default Re: (kid-honda)
Thanks for all the help, any suggestions on a cheap but good buffer ?
Old Mar 10, 2005 | 08:50 PM
kid-honda's Avatar
Makita isnt the cheapest but they come with different handles to better suit your comfort and they are one of if not the lightest buffers out there and they got the best warrenty.
One use on a car will pay for its self and you will use it many times againe.
