Another question about wiring vtec
I was reading about this thread https://honda-tech.com/zerothread?id=919292 and was just wondering,instead of removing the ecu pinouts,can i just splice the wires.Removing the pinouts is a realy PITA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aespooncivic »</TD></TR><TR><TD CLASS="quote">really isnt a pain in the ***... i did it it took like 20 minutes to hook up v-tec in my hatch..if u want to do it half *** u can splice...DO IT RIGHT...
</TD></TR></TABLE>Ok so it works?I know it ghetto but oh well
i just wanna know why ud do a cob job on ur own car maybe a friends car... not even... to each is his own i guess... i feel better after doin a job right ....
uve supplied ur self with a thread with a write up.. follow the instructions and ull be alright..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aespooncivic »</TD></TR><TR><TD CLASS="quote">u peel back teh little plastic piece and push the other end with a screwdriver...</TD></TR></TABLE>With all do respect Aespooncivic,why dou think it is a ghetto job?
why do i think what is a ghetto job.. i just liek doin **** right in my own car thats it if u wanna splice,splice away im just tryin to give good advice
sorry for postin
sorry for postin
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocco. »</TD></TR><TR><TD CLASS="quote">Ok so it works?I know it ghetto but oh well
i also think its a ghetto job cuz u also said ur self it was.....
</TD></TR></TABLE>^^^^^^^^^^^^^^^^^^^^^^^^
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aespooncivic »</TD></TR><TR><TD CLASS="quote">why do i think was is a ghetto job.. i just liek doin **** right in my own car thats it if u wanna splice,splice away im just tryin to give good advice
sorry for postin
</TD></TR></TABLE>No dude,i tried to ask u that unoffensively i swear. I am just trying to gather the disadvantages of just splicing it.Dont be sorry man,its all good.The wires that you remove from the non-vtec ecu,are they going to be of service anymore?
sorry for postin
p72_obd1
A1 BRN INJ1 INJ1
A2 YEL INJ4 INJ4
A3 RED INJ2 INJ2
A4 GRN/YEL VTS VTEC solenoid
A5 BLU INJ3 INJ3
A6 ORN/BLK PO2SHTC O2 sensor (heating element)
A7 GRN/BLU FLR1 fuel pump
A8 (empty)
A9 BLK/BLU IACV IAC valve
A10 (empty)
A11 (empty)
A12 GRN FANC engine coolant temp switch
A13 GRN/ORN MIL MIL (check engine light)
A14 (empty)
A15 BLK/RED ACC (a/c compressor clutch)
A16 WHT/GRN ALT C alternator
A17 PNK/BLU IAB IAB Solenoid
A18 (empty)
A19 YEL (AUTO ONLY) (a/t trans only)
A20 RED PCS EVAP purge control solenoid
A21 YEL/GRN ICM ICM
A22 (empty)
A23 BLK PG1 ground
A24 BLK PG2 ground
A25 YEL/BLK IGP2 to main relay and to gound for o
A26 BRN/BLK LG1 gound
B1 YEL/BLK IGP2 to pin A25
B2 BRN/BLK LG2 ground to shields for CYP & TDC
B3 (a/t trans only)
B4 (a/t trans only)
B5 BLU/RED ACS a/c switch
B6 (empty)
B7 (a/t trans only)
B8 GRN PSPSW PSP switch
B9 BLU/WHT STARTER SIGNAL starter signal
B10 ORN VSS vehicle speed sensor
B11 ORN CYP P CYP -P
B12 WHT CYP M CYP -M
B13 ORN/BLU TDC P TDC -P
B14 WHT/BLU TDC M TDC -M
B15 BLU/GRN CKP P CKP -P
B16 BLU/YEL CKP M CKP -M
D1 WHT/BLU VBU Back Up Power
D2 GRN/WHT BKSW brake switch
D3 KS Knock Sensor
D4 BRN/WHT SCS service check connector
D5 (empty)
D6 BLU/BLK VTM VTEC pressure switch
D7 LT BLU TXD/RXD (data link connector)
D8 (empty)
D9 WHT/RED ALT F alternator
D10 GRN/RED ELD electric load detector
D11 RED/BLK TPS TPS Signal
D12 YEL/GRN
D13 RED/WHT ECT ECT sensor
D14 WHT/RED PHO2S O2 sensor
D15 RED/YEL IAT IAT sensor
D16 WHT/BLK VREF VREF
D17 WHT/YEL MAP Map Signal
D18 (a/t trans only)
D19 YEL/WHT VCC1 MAP 5V
D20 YEL/BLU VCC2 TPS 5V
D21 GRN/WHT SG1 MAP GND
D22 GRN/BLU SG2 TPS GND
A1 BRN INJ1 INJ1
A2 YEL INJ4 INJ4
A3 RED INJ2 INJ2
A5 BLU INJ3 INJ3
A8 (empty)
A10 (empty)
A11 (empty)
A14 (empty)
A18 (empty)
A21 YEL/GRN ICM ICM
A22 (empty)
A23 BLK PG1 ground
A24 BLK PG2 ground
B3 (a/t trans only)
B4 (a/t trans only)
B6 (empty)
B7 (a/t trans only)
D3 KS Knock Sensor
D5 (empty)
D8 (empty)
D12 YEL/GRN
northkai3
Jun 26, 2005 01:35 PM
DOHC_VTEC69
Jan 20, 2005 08:24 PM
