Vtec Kill switch.
Old Mar 7, 2005 | 07:56 PM
HatchBox's Avatar
Skoobie no more...
Default Vtec Kill switch.
Alright well this summer i am going to be commuting alot in my 90 civic with b16 ys1 tranny, so that means crusing the thru-way at 4-5 grand
So its possible that i would be crusing in vtec. (not good for gas )
My question is where would the best place to put a swtich to turn off vtec?
Old Mar 7, 2005 | 07:58 PM
Superhatch's Avatar
Default Re: Vtec Kill switch. (HatchBox)
Electrically, or physically?
Old Mar 7, 2005 | 07:59 PM
PHOBIA's Avatar
wait wait, i thoght vtec was invented to save gas.either way you could just run a toggle to your vtec sylonoide "sp?" and flip it off and on when you want it.thats what i would do any ways.
Old Mar 7, 2005 | 08:06 PM
keebler65's Avatar
Default Re: (PHOBIA)
vtec is only engaged at a certain throttle percentage. therefore, it will not be engaged while cruising -- only under acceleration. there is no need for a switch. also, if you did use a switch, you would throw a code when the switch was off because the ECU would not see the load of the solenoid.
Old Mar 7, 2005 | 08:08 PM
HatchBox's Avatar
Skoobie no more...
Default Re: Vtec Kill switch. (Superhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Superhatch &raquo;</TD></TR><TR><TD CLASS="quote">Electrically, or physically?</TD></TR></TABLE>
Whichever is efficient. I dont wanna switch the wrong wire and bam mess something up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHOBIA &raquo;</TD></TR><TR><TD CLASS="quote">wait wait, i thoght vtec was invented to save gas.either way you could just run a toggle to your vtec sylonoide "sp?" and flip it off and on when you want it.thats what i would do any ways.</TD></TR></TABLE>
Try driving around with a dohc in vtec all day and see how many mpg you get
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keebler65 &raquo;</TD></TR><TR><TD CLASS="quote">vtec is only engaged at a certain throttle percentage. therefore, it will not be engaged while cruising -- only under acceleration. there is no need for a switch. also, if you did use a switch, you would throw a code when the switch was off because the ECU would not see the load of the solenoid.</TD></TR></TABLE>
So if im crusing at 80-85 and i hit 5500 rpm it wont enguage?
You learn something new everyday
Old Mar 7, 2005 | 08:28 PM
TIRENECK's Avatar
This is why I love my VAFC.
Old Mar 7, 2005 | 08:35 PM
keebler65's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchBox &raquo;</TD></TR><TR><TD CLASS="quote">So if im crusing at 80-85 and i hit 5500 rpm it wont enguage? </TD></TR></TABLE>
correct. but the instant that you "get on" the throttle, vtec will turn on.
Old Mar 7, 2005 | 08:40 PM
HatchBox's Avatar
Skoobie no more...
Default Re: Vtec Kill switch. (keebler65)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keebler65 &raquo;</TD></TR><TR><TD CLASS="quote">correct. but the instant that you "get on" the throttle, vtec will turn on.</TD></TR></TABLE>
thanks
Shoot5Hole84
Apr 17, 2010 10:20 PM
sileighty_911
Sep 2, 2007 05:55 PM
philkehn
10
Oct 3, 2006 11:55 AM
da6jdmteg
Jan 18, 2006 08:25 AM
Tatakai
14
Oct 7, 2005 07:03 PM
