FYI: New ATS 3.077 1st Gear! Only $250!!!
Old Jan 22, 2002 | 10:31 AM
_unknown_'s Avatar
Default FYI: New ATS 3.077 1st Gear! Only $250!!!
I just found this on the Racing craft website. Hopefully Yasu doesn't mind me posting this.
Thought you guys who are dropping your trannies in the next couple of weeks would like this.
I am doing a lightweight flywheel and clutch in the next couple of months so I might just do this upgrade as well.
http://racingcraft.com/ats-products-...tio-gear.shtml
Old Jan 22, 2002 | 10:43 AM
EGtoR's Avatar
Default Re: FYI: New ATS 3.077 1st Gear! Only $250!!! (spoonek9)
According to the info in that site, we only need to purchase 1,3,4,5 gear to have the complete ATS gear set now?
Old Jan 22, 2002 | 10:59 AM
B2FiNiTY's Avatar
Default Re: FYI: New ATS 3.077 1st Gear! Only $250!!! (EGtoR)
LOL.
Old Jan 22, 2002 | 11:41 AM
Black R's Avatar
25 Year Member
.....what are you changing? Just 1st gear? Why?
Old Jan 22, 2002 | 12:11 PM
GQ 05YellowEVO8's Avatar
I want one.....Yasu is like a 1.5 hour drive from me, maybe I should pay him a visit.
Old Jan 22, 2002 | 07:07 PM
AJ PwR's Avatar
Yes ! They used to come with the mainshaft but now they just offer a 1st gear to work with the stock mainshaft !
Highly recommended upgrade (close gear ratio)
Old Jan 22, 2002 | 07:48 PM
SpoonCivic's Avatar
New User
Default Re: FYI: New ATS 3.077 1st Gear! Only $250!!! (AJ PwR)
is it a lower first gear? higher? or same gear ratio?
Old Jan 22, 2002 | 08:16 PM
Spikey's Avatar
Default Re: FYI: New ATS 3.077 1st Gear! Only $250!!! (SpoonCivic)
stock 1st gear is around 3.3 if i recall correctly. the new ATS 1st is a 'taller' gear... hence u can stay in first a bit longer, maybe not wheelspin as badly, and not drop as many rpm shifting to second.
ATS gearset uses the stock 2nd gear
Old Jan 22, 2002 | 08:17 PM
SpoonCivic's Avatar
New User
Default Re: FYI: New ATS 3.077 1st Gear! Only $250!!! (Spikey)
interesting..this is a good mod for a turbo vehicle like myself.
Old Jan 22, 2002 | 08:33 PM
AJ PwR's Avatar
Definitely
Almost majority for street racers or weekend racers in Japan , close gear set is the "must" before they go racing. A longer 1st gear always benefit in drag racing with high power engines cuz you will have less wheel spin and easier to hook up during the launch. The reat of the gears will less power lost during shifting.
More hardcore racer like Auto-X (Gymghana) may even run bigger FD with the close gear set to achieve more acceleration.
Old Jan 22, 2002 | 08:52 PM
onyx00's Avatar
So is this just the first gear for $250? Why does that sound high to me...
Old Jan 22, 2002 | 09:21 PM
Spikey's Avatar
Default Re: FYI: New ATS 3.077 1st Gear! Only $250!!! (onyx00)
ACTUALLY, compared to the previous ATS first gear kit, that is REALLY CHEAP!!!!
Old Jan 22, 2002 | 09:35 PM
EGtoR's Avatar
Even it is still very expensive, but for sure much better than the $1000 ppl are charging before for the 1st gear and the same as stock ratio 2nd gear.
Old Jan 23, 2002 | 06:48 AM
DarthLuder's Avatar
New User
So this new 1st gear would be good for like toda b/jun3,b20 setup, and FI setups?
Old Jan 23, 2002 | 07:22 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: FYI: New ATS 3.077 1st Gear! Only $250!!! (O0oToOKo0Oo0OR555)
This would be great for those like myself with the ATS 4.929 FD who might have some traction probs in 1st gear once they make a lot of whp.
So they have one for the USDM shaft? What about the ATS shaft that comes with the 4.929?
EDIT: I do not make a lot of whp - I mean for WHEN I make a lot, or if OTHERS make lots of whp...
[Modified by B18C5-EH2, 11:23 AM 1/23/2002]
Old Jan 23, 2002 | 08:19 AM
VTEC4GS's Avatar
Default Re: FYI: New ATS 3.077 1st Gear! Only $250!!! (TODA RACING)
Toda Racing, where in NY are you from ?
Greg
Rickvanuden
Transmission & Drivetrain
Jun 8, 2017 09:00 AM
Garage786
Dec 5, 2008 09:15 AM
gray_civic_coupe
Sep 16, 2005 01:15 PM
