uberdata for p13
Old Mar 7, 2005 | 07:42 PM
Green Lude 93's Avatar
Default uberdata for p13
i have a 93 turbo lude and ive been looking into uberdata and ditching the vtec controller. i already know how to install it and what ever but i was wondering if it is possible to use uberdata on a p13 ecu? all i read was that all it had to be was obd1 but it would say civic or integra. if all comes to worse i guess i could just get a p72 and use that.
Old Mar 7, 2005 | 07:55 PM
mmuller's Avatar
Mad Scientist
Default Re: uberdata for p13 (Green Lude 93)
edit: i guess not.
Modified by mmuller at 10:04 PM 3/8/2005
Old Mar 7, 2005 | 09:10 PM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Green Lude 93 &raquo;</TD></TR><TR><TD CLASS="quote">i have a 93 turbo lude and ive been looking into uberdata and ditching the vtec controller. i already know how to install it and what ever but i was wondering if it is possible to use uberdata on a p13 ecu? all i read was that all it had to be was obd1 but it would say civic or integra. if all comes to worse i guess i could just get a p72 and use that.</TD></TR></TABLE>
There seems to be more active development with CROME. I believe partial P13 support already exists, and I bet it will be fully implemented in a few months. There is a fair P72 map based on P13 code on the Uberdata and pgmfi.org forums. I just set up a p28 with IAB control for a customer two weeks ago for his H22 EG, and it worked quite well.
Old Mar 8, 2005 | 04:49 AM
Silverpike's Avatar
Default Re: uberdata for p13 (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">sure you can</TD></TR></TABLE>
Ummm, NO.
Currently p13s are not supported. I don't trust Crome with the P13, nobody is using it. If you want to run Uberdata, you will have to use a P72.
Old Mar 8, 2005 | 07:32 AM
mmuller's Avatar
Mad Scientist
Default Re: uberdata for p13 (Silverpike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silverpike &raquo;</TD></TR><TR><TD CLASS="quote">Ummm, NO.
Currently p13s are not supported. I don't trust Crome with the P13, nobody is using it. If you want to run Uberdata, you will have to use a P72.</TD></TR></TABLE>
care to elaborate?
Old Mar 8, 2005 | 01:00 PM
ok. Yea i havent heard to much about crome either. I guess i could get a p72 and then use uberdata with that. Why wouldnt the p13 work? isnt software the same for all the obd1 ecu's? as long as it is tuned for the car.
Old Mar 8, 2005 | 02:57 PM
Silverpike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Green Lude 93 &raquo;</TD></TR><TR><TD CLASS="quote">ok. Yea i havent heard to much about crome either. I guess i could get a p72 and then use uberdata with that. Why wouldnt the p13 work? isnt software the same for all the obd1 ecu's? as long as it is tuned for the car.</TD></TR></TABLE>
You can read all the details on pgmfi.org if you like.
The bottom line is that the p13/Accord code is substantially different from the p28/p72 code. They use different fuel tables, and nobody has invested the time to properly reverse-engineer them (aside from Neptune).
I have never gotten the fuel maps to work under Crome on the P13. Even John Cui tells people not to use P13 roms.
Old Mar 8, 2005 | 10:30 PM
thanx for the info.
teets1888
Jan 5, 2008 01:36 PM
Civic_EX_turbo
Jan 5, 2004 08:43 AM
2SLO
Dec 4, 2003 06:16 PM
ls_vtec_b18a1
Jan 16, 2003 08:11 AM
