ATS Installation....how much will the labor be approx?
Ok, since it will take out the whole tranny to finish the job, what labor rate am I looking at? If it's expensive, what other upgrade parts should I throw in to make the labor a little bit worth its price?
~$400 to pay someone else to do everything.
~$200 to pay someone else to just do the final and pinion install into the case
~free if you do it yourself.
Scratch that, it's priceless!
i was just curious after i finished the install.... my old dealer in pittsburgh would have charged $600 for labor only.
go buy some tools and some beer, and have a fun saturday.
D
D
I would do it when your also doing the clutch. I'll be doing all my tranny stuff at once.
Do it like this Sir:
ATS 4.929 FD
GSR 5th Gear
OEM ITR Clutch or *Insert your Favorite Clutch Here*
*Insert your Favorite Flywheel Here*
Then your setup PHAT SKIllz Y0...
Suprdave
ATS 4.929 FD
GSR 5th Gear
Suprdave
ATS 4.929 FD
GSR 5th Gear
Suprdave
ATS 4.929 FD
GSR 5th Gear
Suprdave
Thats the way to go.
ATS 4.929 FD
GSR 5th Gear
Suprdave
ATS 4.929 FD
GSR 5th Gear
Suprdave
D
D
I have no friends that have the knowledge of doing any complex mechanical works.
And my car sits in a condominium parking lot...imagine jacking up the car with oil everywhere and my super running toward me and screaming -- not a good scene.
Maybe I shouldn't start with a new ITR but a hybrid and do everything myself first.
But at this point, I have no ways to overcome the fear fooling around my car and using it as a white mouse.
Sad but destined -- Whatever mods I purchase wil cost me a great deal of addtional money for someone else to install them.... BTW, how do you become one of those Acura/Honda trained certified technician? Is there a specific school to attend? I figure if those High School grads can do it, why can't I? I plan to read over the Helms manual the next half year then find a tech school to attend.
[Modified by nEoMuGen, 8:11 PM 1/22/2002]
ATS 4.929 FD
GSR 5th Gear
Suprdave
ATS 4.929 FD
GSR 5th Gear
Suprdave
ATS 4.929 FD
GSR 5th Gear
Suprdave
ATS 4.929 FD
GSR 5th Gear
Suprdave
I'll see you on the back straight if that's the case.....
I don't remember at what rpm the ATS maxes out in 4th gear, but I seem to recall it isn't much above 100mph. Correct me if I'm off-base here. You'd need a strong 5th gear to keep pulling down the straights. The gs-r 5th gear will get you nowhere fast.
Let me reiterate: changing only the final drive to ats 4.9 is the preferred setup. If you change to a longer 5th, your rpm drop will be greater from 4-5 shift. You may fall out of vtec. But even if you don't, the only reason to change would be if you cruise at 85mph+ all the time. Otherwise, I'll pass you on the back straight from 4-5 shift.
So, if this is just for a regular driven car, getting a GSR 5th would be fine. Correct? Doesn't the 98spec tranny have a GSR 5th?
this might be a stupid question but when using the ATS Final Drive with stock 1-5, how high would your revs be when cruising at highway speeds such ah 85mph? Thanks.
I know for the JDM FD it adds about 400-500 RPM. Since the ATS is even shorter... I would imagine that you would be around 5000? Correct me for I am just taking a stab.
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
I would think 400-600 depending on who's doing the work. It cost Asspenny about 50-60 beers, some snacks and some sleeping space for his....
65mph at 4k rpms indicated (3800rpms actual)
-70mph at 4200 rpms indicated (4k rpms actual)
-80mph at 4800 rpms indicated (4600 rpms actual)
Anyway, I can only cruise rationally lega at 70mph. I rarely cruise at 80mph unless I am on a long trip of Interstate Highways. At 5000rpm, just upgrade your audio system.
usdm itr tranny no, 5th gear = more agressive.
Ok then....3 kegs of beer and a night at a strip club with 5-min lap dance. Anyone?
