"Gas Gauge Doesn't Work" needle stays above F
Old Mar 7, 2005 | 06:26 PM
slammedef06's Avatar
Default "Gas Gauge Doesn't Work" needle stays above F
after removing indiglow gauges CAREFULLY my gas gauge doesn't work. the needle stays at above full. what can i do to fix this? everything else works perfect. thanks!
Old Mar 8, 2005 | 07:29 AM
Default Re: "Gas Gauge Doesn't Work" needle stays above F (slammedef06)
is there anything i can do?
Old Mar 8, 2005 | 07:33 AM
AutoXer's Avatar
You'll need to replace it. If you have an EK, you can get a new fuel guage from http://www.slhondaparts.com; I'm not sure if you can do that with an EG. Otherwise, you can swap the whole cluster.
Old Mar 8, 2005 | 07:41 AM
Ricey McRicerton's Avatar
Default Re: "Gas Gauge Doesn't Work" needle stays above F (EX_AutoXer)
You broke it when you pulled the needle off.
You need a new one.
Old Mar 8, 2005 | 08:37 AM
Default Re: "Gas Gauge Doesn't Work" needle stays above F (Ricey McRicerton)
thanks for the help! Actually i didn't pull the needles off i worked around them but i must have hit the gas needle by mistake. i guess i'll have to buy a whole new cluster.
Old Mar 8, 2005 | 08:39 AM
You can actually just buy the fuel guage (or the fuel/temp gauge depending on what guages you have in there).
Old Mar 8, 2005 | 09:04 AM
Ls_V_TurboSi's Avatar
for future reference.. If removed them becuase you didnt like them and you were gonna throw them away you shoudl have just cut them off...
4doormob
Jan 11, 2012 07:21 AM
dylokjai
Jul 15, 2008 04:35 AM
Hiroshima_VTi-S
May 30, 2007 10:35 PM
B6tizzleHatch
Aug 2, 2006 07:06 AM
gsr2nite
Jan 22, 2006 08:07 PM
