STR 70 mm TB Surge Problems.....
Old Mar 7, 2005 | 05:25 PM
ITRacer121's Avatar
Default STR 70 mm TB Surge Problems.....
Help Guys! I got this new STR 70mm TB and the idle is jumping from 1k to 3k RPM! I have checked and had No luck with vacuum leaks. The surging goes away when I plug the hole in the Tb and it idles fine when I unplug the IAC sensor but in turn throws a code.
I have already calibrated the TPS to .5V as well and spoken to reps @ STR
I know that if I had an OEM with a fast idle control valve it might repair it but in this case there is not one.
Just wondering if anyone has had this problem and had luck fixing it
TIA
Old Mar 8, 2005 | 06:08 AM
ITRacer121's Avatar
no one knows how to fix this?
Old Mar 8, 2005 | 06:56 AM
ITRacer121's Avatar
anyone know of any negative affects of plugging the hole in the TB?
Old Mar 8, 2005 | 08:11 AM
AllMotorMark's Avatar
Default Re: STR 70 mm TB Surge Problems..... (ITRacer121)
sounds like you have a bad iac or a leak from there also could be a leak or a bad fast idle valve , if you have one
Old Mar 8, 2005 | 01:20 PM
DSRxCandyh2bEG's Avatar
Default Re: (ITRacer121)
Check the gasket and see if its on correctly. You might have a gasket leak...
Old Mar 8, 2005 | 01:23 PM
powerfulperformance's Avatar
Default Re: STR 70 mm TB Surge Problems..... (AllMotorMark)
did you adjust the tps to .49volts? Well the problems is that too much air is entering the car at idle. Make sure the butterfly is closed all the way and use the screw at the top to adjust the idle. Sometimes these aftermarket throttle bodies needs adjusting..
Old Mar 8, 2005 | 07:43 PM
ITRacer121's Avatar
I have calibrated the TPS sensor to .5V like the helms says to
I have checked the gasket by spraying carb cleaner to see if it bogs out and cant find a leak
I do NOT have a fast idle valve
and I have tried adjusting the idle screw but it does NOT seem to do anything
I called the STR guys and they are sending me a new gasket and a redesigned Idle screw so maybe that will do something?
Old Mar 8, 2005 | 08:38 PM
2k.civic.si's Avatar
did u use the gasket that came with the str throttle body? the one that came with mine i had to hole punch so air would go throught he channel to the iac valve...this channel is also where the air from the idle screw comes from....stock gasket bad on stock motor....unless your gonna use the butterly plate screw to keep it open enough to idle properly
Old Mar 8, 2005 | 11:37 PM
Default Re: (2k.civic.si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2k.civic.si &raquo;</TD></TR><TR><TD CLASS="quote">did u use the gasket that came with the str throttle body? the one that came with mine i had to hole punch so air would go throught he channel to the iac valve...this channel is also where the air from the idle screw comes from....stock gasket bad on stock motor....unless your gonna use the butterly plate screw to keep it open enough to idle properly</TD></TR></TABLE>
thats what i was going to ask also. if the gasket you got had a whole in it or not...
Old Mar 21, 2005 | 09:29 PM
BDL IND's Avatar
Default Re: (Candyh22EG)
Have you received the parts we sent out? A port is needed in the gasket in some applications as well. Please call us if you have any further questions or problems.
Old Mar 22, 2005 | 10:14 AM
Jowee's Avatar
Default Re: (STR)
Have they still not sent you the parts they promised yet?
Old Mar 25, 2005 | 01:49 PM
Jowee's Avatar
ITRacer121 has recieved the idle screw, but never got the mother fuggin gasket. Idiots can't get anything right. Please someone post a pic of their STR gasket so I can at least try to help him get that Hype R running.
eskerley
13
Apr 16, 2008 02:59 PM
GreensleeperB16
Aug 5, 2003 07:41 PM
hybrid901
May 29, 2003 07:20 AM
Slain
May 14, 2002 11:25 AM
One8Hatch
Oct 23, 2001 07:16 PM
