Weird Transmission problems
Old Mar 7, 2005 | 03:35 PM
EtchaSketch's Avatar
Default Weird Transmission problems
I have a b18c1 with a GSR short ratio tranny. I had redline MTL in it and had horrible problems , alot of synchro grind and it just wasn't what everyone had said it would be.
So i flushed the tranny and picked out all the shitty particals and put in Redline MT-90 and it improved the shifts but i still got umbral problems with 2nd to 3rd if i am going at any decent speed. Now even shiftin into 4th gives me problems. This is not just with me drivin this is with my mechanic and 1 other experienced driver so its not just related to shiftin differences.
So i just want some thoguths on what to put into the tranny? try Redline MTL again? or go to stock honda stuff. The car does go to the track and will get a LSD put in if the tranny is good. The engine is also being turbo so i wanna kinda fix this tranny problem before i do anything else.
Old Mar 7, 2005 | 04:34 PM
Jim Truett's Avatar
Default Re: Weird Transmission problems (EtchaSketch)
If the synchors are gone, no fluid will help. The only fluid I have had success with curing minor grinds is GM/Pennzoil Synchromesh. Any GM dealer will carry it, and you may be able to find the Pennzoil fluid at a local auto parts store.
Old Mar 7, 2005 | 05:17 PM
Default Re: Weird Transmission problems (Jim Truett)
alright well that is an option. Im going to look at that as well as Redline again but ithink Gm synchromesh is worth a shot.
Should i tranny flush everytime ichange or is it really not worth it?
Old Mar 7, 2005 | 06:02 PM
dragstarr1411's Avatar
the gm synchromesh works probably best of anything i would give it a try
Old Mar 7, 2005 | 08:41 PM
Well i think ill give that a shot, my next question is the Transmission flush or use a magnet or both or what works the best?
I wanna just get this tranny problems solved before i start pumpin money elsewhere into the car that may need money put into the transmission, so this is my main problem right now ,
thx for the help so far
Old Mar 7, 2005 | 09:25 PM
ekb16's Avatar
gearspeed.com has syncros..almost $200 for a set 1-5 and R...
Old Mar 8, 2005 | 03:03 PM
Default Re: (ekb16)
hot damn thx man :D
Old Mar 8, 2005 | 05:05 PM
robbieshonda's Avatar
Default Re: (EtchaSketch)
Id replace the syncros there are only 3 of them. Check your helms. Some mauals take auto tranny fluid instead of 90 wt. if you do your syncros use honda mtf thats whats reccomended
Old Mar 8, 2005 | 05:43 PM
Default Re: (robbieshonda)
Yeah iwas kinda curious on the Honda fluid, if you dont use it right away if you should go back or what? but ill see if my synchros really are fugged and if they are then when i pop the LSD in ill fix them . thx for the help
c.u.one
May 4, 2004 05:50 PM
mehdiR
Mar 12, 2004 07:08 AM
Mostec_EG
May 27, 2003 11:04 PM
ChingonGSR
Apr 18, 2003 11:16 AM
sl0wED
Feb 14, 2003 06:10 AM
