Edelbrock Intake Manifold Questions...
Old Mar 7, 2005 | 02:42 PM
Soccerking3000's Avatar
Default Edelbrock Intake Manifold Questions...
Okay i am looking at edelbrock intake manifolds and they have the extra boses on the bottom for the secondary fuel rail. Now i have seen on numerous occasions on this site that show that the best atomization of the fuel/air is farther back in the runners than the stock location. This can be seen in TWM and Toda ITB setups. I was wondering if it would be possible to thread the stock injector ports and plug them and then put your fuel rail and injectors on the second boses farther back? In theory this should be better, what do you guys think?
Old Mar 7, 2005 | 02:50 PM
jlacoy82's Avatar
71.192.16.183
Default Re: Edelbrock Intake Manifold Questions... (Soccerking3000)
You could try it, but you'd have to buy Edelbrocks own injectors and fuel rail, I dont believe you can re-use either your stock injectors or fuel rail for that.
Oh BTW, I just bought one yesterday, should be in the mail.
Old Mar 7, 2005 | 02:53 PM
Default Re: Edelbrock Intake Manifold Questions... (jlacoy82)
but in theory it should be better right?
Old Mar 7, 2005 | 05:56 PM
SilentWrath's Avatar
in theory yes, but you must also think about how the ecu "knows" when to open and close the injectors and this is programmed for the stock locations
i dont know how much of a difference those 3-4" or so is going to make in injector timing, but its just something to think about
Old Mar 7, 2005 | 06:00 PM
Default Re: Edelbrock Intake Manifold Questions... (SilentWrath)
well what do cars with ITB's do such as the TWM and Toda setups, the injectors are real far back, maybe someone with them could chime in?
Old Mar 7, 2005 | 06:26 PM
TeamNextGenChris's Avatar
i just recently installed that same mani on my car.i wondered the same thing as you,but came to the conclusion that if there was a benefit,wouldn't the manufacturer do it that way in the first place?i am interested in hearing people's theories,but i say that either there's no advantage,or some drawback to it.
BTW-this would be an expensive theory to test as it requires Edlebrock's own injector/rail setup.you may be able to get creative and use the stock stuff,but it definitely doesn't bolt right on.
Chris
Old Mar 7, 2005 | 06:31 PM
Default Re: Edelbrock Intake Manifold Questions... (TeamNextGenChris)
ya i kinda figured that, but i was wondering, since it should be better
Old Mar 8, 2005 | 10:53 AM
bump
Old Oct 29, 2006 | 02:53 PM
oxSLEEPERxo's Avatar
bump from the dead, what did yall use to plug up the extra secondary injector holes if yall didn't use it?
Old Oct 31, 2006 | 10:57 AM
Default Re: Edelbrock Intake Manifold Questions... (oxSLEEPERxo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oxSLEEPERxo &raquo;</TD></TR><TR><TD CLASS="quote">bump from the dead, what did yall use to plug up the extra secondary injector holes if yall didn't use it?</TD></TR></TABLE>
B20VSi2000
May 6, 2016 04:23 PM
maximusmda
Jan 24, 2010 12:05 PM
aznboi_2
Oct 22, 2008 10:47 PM
dabomb
Apr 17, 2003 02:22 PM
aemciv
Mar 24, 2003 10:54 PM
