Need help with ignition wire order (As soon as possible!!)
Old Jan 22, 2002 | 08:13 AM
Westrock2000's Avatar
Default Need help with ignition wire order (As soon as possible!!)
Hey guys, I recently had my ignition wires stolen (and they were the cheap $30 pepboys OEM ones ). Anyways I looked at my Hanes manuel and I hooked it up in the order it shows, but my car wouldn't start, and looking on the internet at pictures it looks like it may be different that what the book says, but I couldn't be for sure. So here is the order it shows in the book
*This is for an LS by the way*
distributer order: (looking from passenger side of vehicle)
23
14
Cylinder order: (From front of vehicle)
4321
Does that make sense to everyone? If you could please go look at your Teg and confirm the order I would be eternally gratefull!!
Old Jan 22, 2002 | 08:43 AM
kikkoboyie's Avatar
New User
Default Re: Need help with ignition wire order (Westrock2000)
im not a smart man, but all the wires should be different length, the shortest should be on the cylinder closest to the distributor, longest on the on farthest away
Old Jan 22, 2002 | 08:55 AM
akhom's Avatar
Default Re: Need help with ignition wire order (kikkoboyie)
try this
34
12
on the wires.
Old Jan 22, 2002 | 09:44 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Need help with ignition wire order (akhom)
try this
34
12
on the wires.
That's it, firing order is 1-3-4-2, so when the dist. rotor is rotating around (clockwise in this diagram), it will go 1 to 3 to 4 to 2.
Old Jan 22, 2002 | 11:22 AM
Default Re: Need help with ignition wire order (PatrickGSR94)
Thanks,
You guys rule!
Old Jan 22, 2002 | 11:30 AM
junglistgsr's Avatar
they is correct. make sure if the car doesnt start that your ignitor coil is in good shape
eth0r
Apr 23, 2007 06:19 AM
timstan
Mar 12, 2005 05:49 PM
f1uxx
Jul 29, 2003 01:33 PM
Duckz
Aug 12, 2002 10:18 PM
Lam
Jan 29, 2002 10:57 AM
