tach/hazard question.
Old Mar 7, 2005 | 10:45 AM
InMyProject's Avatar
Default tach/hazard question.
maybe someone knows how these circuits work..
my tach and warning lights in the cluster will stop working...turning the hazards on and back off fixes it..
any ideas why?
Old Mar 8, 2005 | 07:46 AM
Default Re: tach/hazard question. (InMyProject)
ttt.
Old Mar 8, 2005 | 07:51 AM
PHOBIA's Avatar
that odd because you hazards work independent of the tach. the only thing they interact with is your turn signals.
Old Mar 8, 2005 | 08:26 AM
the hazards only interact with the turn signals?
it does it quite often now.. there is definitely a short.. I'm just tryig to get a heads up on where to start.
Old Mar 8, 2005 | 08:31 AM
PHOBIA's Avatar
yup, if you take out your hazard switch the only thing that will be affected is you wont have any turn signals. im sorry i cant help more. i would take off the column cover and start looking around with a voltameter. maybe some were along the harness some wires melted together or grounded out and its causing some funk interference. i to have a had some bad problems with gauge clusters. i havent had any lights in there for over a year.
Old Mar 8, 2005 | 11:29 AM
Default Re: (PHOBIA)
when it goes weird.. the gauge lights are the only things that do work. the warning lights(seatbelt, brake, etc) go out along with the tach. maybe its a bad ground.. or something.
Old Mar 8, 2005 | 11:56 AM
PHOBIA's Avatar
the best thing to do, is pull the cluster and start loking around for any bad conections.
Old Mar 9, 2005 | 05:33 AM
anyone else?
Old Mar 16, 2005 | 07:49 AM
ttt, anyone know which circuit this is?
CaptainQuirk
Jul 11, 2007 12:09 PM
verycleanhatch
May 30, 2006 01:49 PM
92'si
Nov 12, 2005 09:07 AM
OneZero1010101
Jun 19, 2004 02:09 PM
