Energy motor mount insert(searched)
Old Mar 7, 2005 | 10:03 AM
Corinthians's Avatar
Default Energy motor mount insert(searched)
After reading 300+ post ,i just want to confirm that is there any vibration and how bad it can be. And the other thing is does it help to improve top speed driving (180km)my car feel like unstable on high speed may be suspention too stiff.
Old Mar 7, 2005 | 10:04 AM
B2FiNiTY's Avatar
Default Re: Energy motor mount insert(searched) (Corinthians)
It will cause increased vibration but it's not to bad to me. For some, it maybe too much though.
Old Mar 7, 2005 | 10:29 AM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Corinthians &raquo;</TD></TR><TR><TD CLASS="quote">After reading 300+ post ,i just want to confirm that is there any vibration and how bad it can be. And the other thing is does it help to improve top speed driving (180km)my car feel like unstable on high speed may be suspention too stiff.</TD></TR></TABLE>
You get used to the vibration pretty quick. It's not a big difference if you already have an exhaust and/or intake, but you'll notice it.
It will do NOTHING for straight-line cruising stability.
Old Mar 7, 2005 | 10:54 AM
slackeR1366's Avatar
they will cause vibration, but I've gotten used to it..it's not bad.
Old Mar 7, 2005 | 11:34 AM
DC2IntegraTypeR's Avatar
Same here. The vibrations annoy me sometimes. But I just close the windows and turn the music up. No more annoyance
Old Mar 7, 2005 | 11:44 AM
Dr Pooface's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Corinthians &raquo;</TD></TR><TR><TD CLASS="quote">After reading 300+ post ,i just want to confirm that is there any vibration and how bad it can be. </TD></TR></TABLE>
You've read over 300 posts, so you know the answer to this question already.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Corinthians &raquo;</TD></TR><TR><TD CLASS="quote">does it help to improve top speed driving (180km)my car feel like unstable on high speed may be suspention too stiff.</TD></TR></TABLE>
No, motor mount inserts will not improve top speed driving, which I presume you are doing on a race course. The only thing they will improve is wheel hop. Sounds like you need an alignment, or more likely, to slow down.
https://honda-tech.com/zerothread?id=178918
Old Mar 9, 2005 | 08:15 AM
Default Re: Energy motor mount insert(searched) (Dr Pooface)
no is for street use,any idea what can improve stability for top speed.I heard injecting some window seal or sealant is good for wheel hop as well an no vibration.Yup no vibration.
Anyway anyone have any idea should i use spherical bearing and pu(energy) ?
Which part should i use energy and which part should be stock
Old Mar 9, 2005 | 08:21 AM
Bbasso's Avatar
want to get rid of wheel hop, or most of it?
https://honda-tech.com/zerothread?id=172247&page=1
Old Mar 9, 2005 | 09:05 AM
Default Re: Energy motor mount insert(searched) (Bbasso)
too costly for street be able to fab the same thing for less cost
Old Mar 9, 2005 | 10:08 AM
PM-Performance's Avatar
they will not help top speed. lol
They will help alot for keeping the engine from moving and wheel hop. But wont cure all of it. You need pretty much all of the mods to help the most
Yes it vibrates. And Yes I loved it. Nothing like seeing a lopey ITR at a light with its mirrors rattling. lol. People used to look at me like i was strange. lol
Old Mar 9, 2005 | 10:13 AM
Bbasso's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Corinthians &raquo;</TD></TR><TR><TD CLASS="quote">too costly for street be able to fab the same thing for less cost</TD></TR></TABLE>
Once again I did not understand what you said...
For $300 you could pick up a traction bar set up and install it yourself.
I picked my Z10 bars for 300 and had a friend install them cause he works at a local shop that has a lift and air tools.
Old Mar 9, 2005 | 10:54 AM
B18CXr's Avatar
The ES mounts is one of the best mods for the money you can do.
Old Mar 9, 2005 | 10:57 AM
Default Re: Energy motor mount insert (B18CXr)
and them top them with some Prothane uppers and its even better.
then add some traction bars and some really nice shocks and springs and stiffen things up and its unbeleivable.
Old Mar 9, 2005 | 02:46 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: Energy motor mount insert (itr206)
I, too, was worried about the vibration. But I got them, installed them and to my surprise, barely noticed the vibration.
Old Mar 9, 2005 | 03:04 PM
ChaseIntegra's Avatar
Default Re: Energy motor mount insert (Gee3)
Yes it vibrates, no it's not that bad.
Old Mar 10, 2005 | 07:53 AM
Default Re: Energy motor mount insert (ChaseIntegra)
anyone can try to explain how badis the vibration and what kind of sacrify for comfort. Anyone who with spouse or wife or gf sitting at the passenger side ,did they compalin?
Old Mar 10, 2005 | 08:12 AM
Default Re: Energy motor mount insert (Corinthians)
if you are worried about comfort, you shouldnt be trying to build a hi hp Honda.
Old Mar 10, 2005 | 10:21 AM
for hi hp not necersarry sacrify comfort --- check out ferrari ....
Old Mar 10, 2005 | 10:32 AM
fullraceacura's Avatar
ferrari huh? its hard to compare a ferrari and a honda becaus:
well ferraris cost 100x as much
the engine is mounted behind the seats in a carbon fiber "bucket"
and well hondas use 3 little sissy mounts to hold an engine in the car, check out how ferrari mounts engines, its just a little different
Old Mar 10, 2005 | 10:34 AM
There is a difference Ferraris were built with utmost performance in mind. Hondas werent ness built for that.
If you cant deal with a little vibration, then dont do them. Simple as that.
They arent that bad, but it will rattle and it will likely shake your side mirrors and rear view mirror a little.
You add the uppers and it will shake more. But you get used to it.
If you have loose change in the coin tray or ash tray, then yes they will get on your nerves becuase you will hear them jumping around like mexican jumping beans.
Old Mar 10, 2005 | 10:41 AM
RTW DC2R's Avatar
after i installed my mounts, my 5th gear vtakkk hits HARD!!!
Old Mar 10, 2005 | 10:45 AM
Default Re: (RTW Ryan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW Ryan &raquo;</TD></TR><TR><TD CLASS="quote">after i installed my mounts, my 5th gear vtakkk hits HARD!!! </TD></TR></TABLE>
Dont lie. everyone knows you cant hit vtak in 5th. Its a Honda, there isnt enuff highway to get these pigs upto that speed.
Pete who could get from 0-vtak in 5th in about 4 seconds due to tremendous traction problems. But oooooooh all the pretty smoke.
Old Mar 10, 2005 | 11:31 AM
RTW DC2R's Avatar
yeah im lying lol
pretty smoke
Old Mar 10, 2005 | 12:09 PM
Marlon88's Avatar
You should come in mine , I have the 3 enjo mount set with the other 2 energy suspension inserts , it shakes alot , alot that I can`t put any thing in the glove box because it anoys me but I got used to it , feels like a true race car .
go for it you will notice the difference and you will like it
Good luck.
Marlon
Old Mar 12, 2005 | 07:59 AM
Default Re: (Marlon88)
i drove my fren's race car today with spoon mounting---- it is like **** man,not going to put insert cause with full insert it will cause the same amount of vibration with the spoon mount.
Friend told me to use some sealant or window weld no vibration and no wheel hop
