gsr cams in b16 head
i have some gsr cams/springs/valves and was wondering if there would be any significant difference if i put them in my b16. i have an ls block that i plan on doing lsvtec with and turbo in hopefully near future. i have jun cam gears that i plan on using, just wondering which cams to put them on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esp4life »</TD></TR><TR><TD CLASS="quote">i have some gsr cams/springs/valves and was wondering if there would be any significant difference if i put them in my b16. i have an ls block that i plan on doing lsvtec with and turbo in hopefully near future. i have jun cam gears that i plan on using, just wondering which cams to put them on.</TD></TR></TABLE>
The B16A1 cams are the weakest B series cams made. GSRs are slightly better than the A2s. It wouldn't hurt to run the GSRs, although I would recommend a set of CTR cams if you plan on keeping it OEM.
Modified by LSVTEC 91 Civic at 5:38 PM 3/7/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esp4life »</TD></TR><TR><TD CLASS="quote">how do you mean weakest? </TD></TR></TABLE>
Least amount of lift and duration compared to all other B series cams.
should i make any other changes to the engine or ecu? will i need a gsr timing belt? i know there will be more to it than taking out the old cams and putting in the new ones ... what all will i have to do?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esp4life »</TD></TR><TR><TD CLASS="quote">should i make any other changes to the engine or ecu? will i need a gsr timing belt? i know there will be more to it than taking out the old cams and putting in the new ones ... what all will i have to do?</TD></TR></TABLE>
It's a direct swap, you can use your B16 timing belt. Also that's all there is to it...just taking out the B16 cams and dropping in the GSR's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic »</TD></TR><TR><TD CLASS="quote">
Least amount of lift and duration compared to all other B series cams. </TD></TR></TABLE>
..mainly the cams out of auto 1st B16's are really really really amusing to look at
GSR cams are worthy upgrading to, they'll give you a little more torque over any generation of B16A cams. Of course Type-R cams are choice over any of the OE VTEC B-series cams.
