started brazing today...
Old Mar 7, 2005 | 09:12 AM
TIGboy's Avatar
Default started brazing today...
well today I started to braze some 1/4 thick metal which was fun but I could'nt keep the puddle straight to make good beads, I had my heat right I have my psi right maybe its because I dont have to steady of a hand but any input would help thankyou
Jon
Old Mar 7, 2005 | 12:01 PM
delslow94's Avatar
Default Re: started brazing today... (Profounder)
how close is the feather of the flame to the piece your working on? make sure your on a neutral flame and take your time. preheating the seam your working on helps too. good luck
Old Mar 7, 2005 | 01:10 PM
ManBearPig4silly's Avatar
it just takes a lot of practice. I actually brazed before i learned to weld. preheating will help and make sure you are running hot enougt o get the filler flowing into the seam properly.
Old Mar 7, 2005 | 06:38 PM
TIGboy's Avatar
Default Re: (silly4lude)
yea I preheat good and that seems to help a lot, my teacher told me the exact same things thanks for the possitve replys.
Old Mar 7, 2005 | 08:34 PM
oxSLEEPERxo's Avatar
Default Re: (Profounder)
once you are done, take pics
Old Mar 8, 2005 | 08:29 AM
TIGboy's Avatar
Default Re: (oxSLEEPERxo)
im still not really getting the hang of it I have to turn up the heat. ill lay a little bit more then ill take some pics
wantboost
Jul 12, 2013 02:46 AM
Ill Mitch
Aug 15, 2006 04:40 AM
thk
Oct 15, 2004 02:38 PM
lahight
Mar 9, 2003 05:49 PM
