10.9 on Street ET's at Georgia 3/S Track Day
Our car ran in the quick 8 class and won 1st place against a 95 Supra w/ single turbo upgrade.
Had to be on street tires so we used MT DOT 26" Street ET's
We had low boost (15psi) from 1st, 2nd, and in 3rd-4th gear 27psi
Best time was a 10.9@143mph with high 1.8 60ft.
Won with 11.12@143.90mph and high 1.9 60ft
GA 3/S Track Day
Will be running with 25" M&H Drag Slicks at the next event.
Setup:
Neukin Turbo Manifold
T4/T67
B18C 84mm
AEBS Sleeves
Modified by 93H22ACX at 12:14 PM 3/7/2005
GA 3/S Track Day
Setup:
T4/T67
B18C 84mm
AEBS Sleeves
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93H22ACX »</TD></TR><TR><TD CLASS="quote">Our car ran in the quick 8 class and won 1st place against a 95 Supra w/ single turbo upgrade.
GA 3/S Track Day
Setup:
T4/T67
B18C 84mm
AEBS Sleeves
Modified by 93H22ACX at 12:14 PM 3/7/2005</TD></TR></TABLE>
Nice run on the M/T 93H22ACX.
John@M&H-Hashims
GA 3/S Track Day
Setup:
T4/T67
B18C 84mm
AEBS Sleeves
John@M&H-Hashims
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowsi00 »</TD></TR><TR><TD CLASS="quote">i am guessing these passes were made on the et street which is bias ply.
that is correct. MT DOT 26x8x15 Street ET
Neukin manifolds are awsome in quality and performance
Thanks to John@M&H we'll be using the 25" slicks this weekend. Finally mounted them.
Final Round
Modified by 93H22ACX at 9:22 AM 3/8/2005
Final Round
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC-dood »</TD></TR><TR><TD CLASS="quote">What is the susion setup? If you dont mind me asking</TD></TR></TABLE>
kyb adjustable shocks with skunk2 coil-overs, skunk2 drag springs, full-race traction bars and OEM axles.
still need a better suspension setup though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic »</TD></TR><TR><TD CLASS="quote">what kind of boost control are you using</TD></TR></TABLE>
profec b with greddy button to switch from low/high boost
still need a better suspension setup though.</TD></TR></TABLE>
OEM axles?!?!?!?! WOW!!!
I was only makin low 300's and I couldnt manage to keep those together... You must be preloading or doin something else... Whats your secret??? lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedCivicSedan »</TD></TR><TR><TD CLASS="quote">
I was only makin low 300's and I couldnt manage to keep those together... You must be preloading or doin something else... Whats your secret??? lol</TD></TR></TABLE>
yes. preload the clutch as high as possible.. the refurbished ones broke, but the OEM ones held up.
RyanEJ8
Mar 7, 2006 05:06 PM
integra_gsr98
Jun 11, 2003 06:21 AM
