Aircraft Remover on GSR Blades
Old Mar 7, 2005 | 06:41 AM
JapJunkie's Avatar
Default Aircraft Remover on GSR Blades
I just came up on a set of GSR blades and since they are pretty old i was wondering if taking AR would take out all the blemishes and places where the clear coat seems to look baked? Ill be keeping them chrome as well, im not going to be doing some whack DIY powdercoat. Thanks in Advance.
Pretty much is this a good method to go by?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec66 &raquo;</TD></TR><TR><TD CLASS="quote">So after 4 days of aircrafting,wet sanding,getting blister on my hands,and polishing this is my DIY polished hx rims
aircraft remover in the can---spray it all over the rim, let sit for 15 mins, wip down then rinse off, then repeat x2 times.
600-800 grit wet sand down the outter walls,lip, and all polished area, make sure u go with the grain, dont do up ,down ,right,left , you will be wet sanding for about 2-3 hours depending on how fast u want them done..lol
gloves cuss the **** burns bad
rags for wiping down the rims
pressure washer to rinse the rims, once u have all the oem paint off and can start to polish them
i used mother's chrome polish /applyed it with a lil buffing dabber, then used a reg towel, once it turns to a black mildo, wipe hard with a microfiber towel, trust me you want the micro fiber, makes them BLING BLING.
And once your done with all of that you get this:
total cost 9.98 for 2 cans of aircraft, 6.99 for 1 jar of jasco, didnt use it much, still works though, and 3.49 for mothers polish </TD></TR></TABLE>
Old Mar 7, 2005 | 07:06 AM
JapJunkie's Avatar
Default Re: Aircraft Remover on GSR Blades (JapJunkie)
bump
Old Mar 7, 2005 | 07:07 AM
743 Stunna's Avatar
only thing i would recomend is going to a higher grit sandpaper ie:
start with like 400 grit
then maybe 600-800
then like a 1400
and finich with like 2000 grit
blades come stock with a really fine finish and u'll need a high grit to get the stock look back
Old Mar 7, 2005 | 07:10 AM
743power's Avatar
Default Re: Aircraft Remover on GSR Blades (743motorsport)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 743motorsport &raquo;</TD></TR><TR><TD CLASS="quote">only thing i would recomend is going to a higher grit sandpaper ie:
then maybe 600-800
then like a 1400
blades come stock with a really fine finish and u'll need a high grit to get the stock look back</TD></TR></TABLE>
and you will need to put some GOOD clear on them unless you want to be outside on your knees polishing them 2 times a week.
Old Mar 7, 2005 | 07:12 AM
JapJunkie's Avatar
then maybe 600-800
then like a 1400
Thanks that was wat i was thinkin...maybe go higher on the grit
I just dont wanna **** up my wheels
Old Mar 7, 2005 | 07:14 AM
JapJunkie's Avatar
Default Re: Aircraft Remover on GSR Blades (743power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 743power &raquo;</TD></TR><TR><TD CLASS="quote">
and you will need to put some GOOD clear on them unless you want to be outside on your knees polishing them 2 times a week.</TD></TR></TABLE>
I read if ur wheels are made of alloy which most are, then u dont have to worry about rust....
Old Mar 7, 2005 | 07:21 AM
TRD MA70's Avatar
1st off, those steps posted above are steps for polishing a wheel. By polishing them, you wont be ''keeping them chrome''. 2nd off you want to start low and go high. When I polished my Cam covers, I used 180, 400, 500, 800, 1000, 2000, but they also didnt come out perfect. You want to use every grit possible. Dry sand until about 320 then wet sand 400, 500, 600, 800, 1000, 1200, 1500 (or 1600, for get which one is next) then 2000. After that you take the polish (I used Mothers metal polish) and rub it on teh surface with a towel until the compound turns black (you'll see what I mean), then wipe it off and rub it until you can't see any blemishes. I dont know about clear coating over them because I havent tried it myself but I CAN garuntee you're going to be re-polishing them every weekend or so if you just leave the polished finish open to the ''elements''.
If you want them chrome then take them to a chroming shop. I'd also be interested in seeing your "DIY powdercoating" station. How is powdercoating ghetto? I always thought rattle can'ing wheels was ghetto. Guess I'm just not ''in'' anymore.
Old Mar 7, 2005 | 07:22 AM
TRD MA70's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JapJunkie &raquo;</TD></TR><TR><TD CLASS="quote">
I read if ur wheels are made of alloy which most are, then u dont have to worry about rust....</TD></TR></TABLE>
He's not saying that because of rust. The polished finish will tarnish and get dirty and its a bitch to clean and keep clean.
Old Mar 7, 2005 | 07:34 AM
JapJunkie's Avatar
Default Re: Aircraft Remover on GSR Blades (TRD MA70)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TRD MA70 &raquo;</TD></TR><TR><TD CLASS="quote">
If you want them chrome then take them to a chroming shop. I'd also be interested in seeing your "DIY powdercoating" station. How is powdercoating ghetto? I always thought rattle can'ing wheels was ghetto. Guess I'm just not ''in'' anymore.</TD></TR></TABLE>
Thats exactly wat i mean bro, rattle canin... Get it DIY powdercoat...?
silver_gs-R
Feb 18, 2008 09:08 PM
B18Flip
Paint and Body
Sep 28, 2007 02:00 PM
pjd
May 5, 2007 01:08 PM
EGcivicBoy
Nov 21, 2003 08:28 PM
redrex
Sep 14, 2003 12:27 PM
