ls tranny shift at high rpm
Old Mar 6, 2005 | 10:06 PM
lsvtec90's Avatar
Default ls tranny shift at high rpm
im running a lsv w/ ls tranny for now and just put my bc3+ on it. when revving it to 8.5 it wont shift right away and when you wait about a couple seconds it will go in good. when i have the gsr cams it, it was fine shifting at that high. dose anyone have any problem? is it just the tranny? do i need a vtec tranny instead?
Old Mar 6, 2005 | 10:26 PM
jizno's Avatar
Default Re: ls tranny shift at high rpm (lsvtec90)
i think a vtec tranny might not be a bad idea
Old Mar 7, 2005 | 01:03 AM
Takumi Fujiwara's Avatar
Default Re: ls tranny shift at high rpm (jizno)
How are your motor/torque mounts? I was having the same issue as you at high RPMs. When I took my driver's side mount on, the rubber was hanging in there for dear life. After I installed some inserts, my shifting is much, MUCH better.
Maybe your engine is rocking back & forth more than before.
Old Mar 7, 2005 | 08:55 AM
lsvtec90's Avatar
Default Re: ls tranny shift at high rpm (Takumi Fujiwara)
maybe, ill check and give it a check. good thinking thanks
beatthisspeed69
Feb 18, 2008 08:09 AM
SilverCG
Aug 14, 2007 12:39 PM
GuateskateVti
Sep 21, 2005 11:11 AM
B20T CRX
May 22, 2004 10:51 PM
Jmm0056
Jun 25, 2001 07:23 PM
