clutch willl not engage to put it gear
Old Mar 6, 2005 | 09:12 PM
del lude's Avatar
Default clutch willl not engage to put it gear
hey whats up me n my cousin was racing this buick v6 turbo and we took off we were even then i went o pput it in third and the clutch just went to the floor and it wouldnt go int o gear so i stopped and it wouldnt go in gear but it felt like my clutch was still there please let me know what u think it is it is a civic 4 door with a gsr motor
Old Mar 6, 2005 | 09:29 PM
Kendall's Avatar
Check the fluid (assuming it's a hydraulic actuated clutch), or check the cable (assuming it's a cable actuated clutch). If the fluid reservoir is low/empty, or the cable is broken, then the solution should seem obvious.
Old Mar 7, 2005 | 07:21 AM
EnjoyTheRideDC2's Avatar
Default Re: clutch willl not engage to put it gear (del lude)
I know the feeling....sorry to say this, but no need to check your fluids, reservoir, or clutch master/slave. I can almost assure you it's your pressure plate. Replace that or the whole clutch assembly, since it's already out.
Old Mar 7, 2005 | 12:09 PM
del lude's Avatar
Default Re: clutch willl not engage to put it gear (EnjoyTheRideDC2)
i think u r very wrong and it is the clutch fluid i am going to put some in it and ill let u know if it works
Old Mar 7, 2005 | 03:26 PM
I totally misread your thread....I thought it said you felt like the clutch wasn't there anymore. I apologize, it could be the fluid/master and slave.
WHen the same incident happened to me, I was on the freeway down shifting into 4th to take a turn and felt the same thing. I tried to shift back up to 5th, NOOO way. THen trying to get into any gear, same thing.
andlude
Apr 5, 2012 07:45 PM
FRKWOO
Aug 1, 2009 04:58 AM
hondaeg95
11
Oct 28, 2005 08:18 PM
dexy
Jan 11, 2005 09:53 AM
dexy
Jan 10, 2005 10:17 AM
