*HELP* OIL IN SPARK PLUG AREA~!!
Old Mar 6, 2005 | 08:29 PM
digital sol's Avatar
Default *HELP* OIL IN SPARK PLUG AREA~!!
my brother and me share a car to drive so we dont have to put too many miles on our del sol's, yea sol's as plural we both own 1. However it randomly died one day while driving, first i check the spark plugs, when i pulled the wires all 3 cylinders looked clean however 1 of them has like 1" of oil sitting in it, it seems its leaking oil into the cylnder spark plug area and thats probably killing the spark which makes the car die right after it starts or sometimes not start at all, ill try to take a pic tomarrow but i described it exactly how it is
what causes this?
what needs to be replaced?
how expensive can this be?
its a 88 or 89 acura integra, dohc, w/130k miles, car was never *NEVER* driven hard sense we've owned it, a girl owned it before us but weve had it sense around 50k miles, id like to get this running again so i can avoid so many miles on my del sol driving to work
thanks guys, i appreciate it
Old Mar 6, 2005 | 08:40 PM
Default Re: *HELP* OIL IN SPARK PLUG AREA~!! (digital sol)
i just searched sense the search is back and working agian and found that more then likely i have to replace the
cover gasket/spark plug tube seals
do i just have to pull the valve cover to change these? or do i have to pull the head completly to do this?
im sure autozone sells these and im gonna pick it up tomarrow and try and get it fixed, ill let you know how it goes
Old Mar 6, 2005 | 08:41 PM
pontiac power's Avatar
nope just the cover
Old Mar 6, 2005 | 08:44 PM
cnydc2's Avatar
You prolly just need the spark plug tube gromets/seals. The valve cover gasket is prolly OK. The oil will leak down the threads and foul out the plug, I think that is definatly your problem.
Old Mar 6, 2005 | 08:46 PM
Default Re: *HELP* OIL IN SPARK PLUG AREA~!! (cnydc2)
ok, ill start by just replacing the seals/garmets but the valve cover seal is cheap anyways so might as well replace it either way
do i have to pull the head? or just the valve cover to replace the seals/garmets?
Old Mar 7, 2005 | 04:22 AM
JimBlake's Avatar
Just the valve cover.
Old Mar 7, 2005 | 05:02 AM
s2kkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by digital sol &raquo;</TD></TR><TR><TD CLASS="quote">ok, ill start by just replacing the seals/garmets but the valve cover seal is cheap anyways so might as well replace it either way
do i have to pull the head? or just the valve cover to replace the seals/garmets?</TD></TR></TABLE>
Paid 20 bucks for the whole valve cover seal kit with the plug seals, valve cover seal, and top bolt grommets
Made by fel-pro, Got it at advance auto parts
Old Mar 7, 2005 | 09:19 AM
kreamy's Avatar
it is recommend to change the grommets and the valve cover seal at the same time so that one doesnt sit higher than the other. They must settle evenly for a proper seal. The set is pretty cheap and everyone makes them.
candyla88
Apr 7, 2013 07:40 PM
CRZ1
Apr 26, 2009 08:59 PM
ls19integra95
Mar 16, 2008 05:51 PM
Michler
Apr 17, 2006 06:59 PM
mongoliandonuts
Aug 27, 2004 11:51 PM
