stock spring drop
ok i have a buddy that makes springs for a living. he said he can "refit" my stock springs to make my car lower. i want to drop them 2". does that sound like a good idea??
yea all he will do is heat em an sompress them which sux cause you want a progressivly wound sring,youll have a super shitty ride with that and the springs get weak after being heated
As you lower your car, you need to increase the spring rate to be able to work correctly with the reduced available stroke and keep from bottoming. That is why all lowering springs increase spring rate as they lower the car. A two inch drop is quite a bit for a Honda suspension to begin with so doing it with no increase in spring rate is setting yourself up for a regularly bottoming car.
If this was not going to cost you any money and you were already planning on buying proper lowering springs and other shocks and throw away your stock springs and shocks, then this experiment will only cost you your labor time and sacrifice the springs and shocks as garbage so long as you don't damage any other parts of the car. If your shocks are good now and you hadn't planned on replacing them, this will almost certainly kill them.
If your friend really does this for a living, he is a hack and I bet and hope he doesn't make much of a living screwing up people's cars taking advantage of their lack of understanding.
he makes springs for a living but this was baically an experiment. didnt know the pros or cons of if thats why i asked if it was a good idea.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 »</TD></TR><TR><TD CLASS="quote">Kick him in the ***** and go buy some springs. My eibach sportlines look good. 1.8" drop And ride better </TD></TR></TABLE>
no i wont do that cause i already grabbed his nips with jumper cables. (meant to grab his shirt and scare him but got oo close oops
very bad idea to cut springs...but just in case you go ahead with the experiment..don't heat up the springs and torch it, use something else(forgot what it's called)
i was told you need to mark the springs while they are still sitting on the struts before you make the cut...
but yeah...hopefully you won't drive with a cut springs...kinda dangerous from what i heard and it's illegal in some states
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by apm »</TD></TR><TR><TD CLASS="quote">very bad idea to cut springs...</TD></TR></TABLE>
no i will never cut a spring and use it. he was going to "reheat" it and refit it to be shorter
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Lee »</TD></TR><TR><TD CLASS="quote">
If your friend really does this for a living, he is a hack and I bet and hope he doesn't make much of a living screwing up people's cars taking advantage of their lack of understanding.</TD></TR></TABLE>
LOL
LOL
And ride better
