IM for n/a ls
Old Mar 6, 2005 | 07:25 PM
BuyImports2's Avatar
Default IM for n/a ls
ok, multiple people have recommended skunk2 IM. i was wondering if there was a certain IM for midrange power. I've got a daily driver, looking to get 150-160whp. how many different IM's does skunk2 make? do they have one specific for mid-range power? (their website only shows one per engine type)
Old Mar 6, 2005 | 09:09 PM
Kendall's Avatar
I do believe that Skunk2 only has one manifold for the LS.
Old Mar 6, 2005 | 09:58 PM
hybrid_vtec's Avatar
Default Re: (Kendall)
Yes Skunk2 and Blox only make one IM for the LS/B20. Your only other option is to port the stocker, which I am in the middle of porting one of mine now to test against my Skunk 2 IM, b/c I believe the longer runners will produce good midrange and better torque #'s while still making good topend power as long as you dont go over 9K(In which only few do).
Old Mar 6, 2005 | 10:13 PM
Default Re: (hybrid_vtec)
please post the results of you comparison. it appears that the skunk2 has shorter, wider runners. for midrange power i need the longer, narrower ones such as found on my stock header. i would like to think that someone out there makes an aftermarket IM for midrange power...
Old Mar 6, 2005 | 10:21 PM
Default Re: (BuyImports2)
I am a busy person so it may be end of the month before I have it done.Just watch and see when i post it up.
Old Mar 7, 2005 | 06:16 AM
JeremyL's Avatar
ehhh screw it just switch to carb
Old Mar 7, 2005 | 06:17 AM
Default Re: (JeremyL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JeremyL &raquo;</TD></TR><TR><TD CLASS="quote">ehhh screw it just switch to carb</TD></TR></TABLE>
I looked into this but they are worse to tune than ITB's
Old May 6, 2005 | 03:43 PM
JeremyL's Avatar
id like to see an idividual carb setup...now that be seriously unique
Old May 6, 2005 | 10:37 PM
sidee draft carbs would be crazy, but a lot more tuning than ITB's
hybrid_vtec
20
Mar 1, 2005 02:00 PM
CivicSiDriver02
Aug 12, 2004 10:26 AM
gsrguy
Feb 3, 2004 01:36 AM
