Baseline .BIN for bolt-on Type-R. Anyone have one they can share?
As topic states, looking for a .BIN file that someone has tweaked a little for a bolt-on Type-R motor. Any 1.8L mild build would work too.
Thanks in advance,
Marshall
Thanks in advance,
Marshall
Thanks for the prompt response mmuller.
However, I am more interested in one someone has spent some time with tuning and whatnot, but anything will work, seeing as it will be only a temporary fix until the ITB's are finished.
http://www.pgmfi.org/twiki/bin...Codes
I searched around in there for a while and found a few B18C5 .bin's, but there is not a lot of info regarding those files. I will probably give those a shot this week once I get a couple more flash chips.
If someone has any more insight, please share.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller »</TD></TR><TR><TD CLASS="quote">mmm obd2, nice and spiky.</TD></TR></TABLE>
Care to elaborate? I don't quite follow. Will there be a problem running a .bin off the site I linked?
I have Hondata .bin files for my ITR, but it looks like you are looking for another type of .bin file?
I have a program that can convert Hondata files to Uberdata. So that would be fine.
I don't know how well/what you tuned for on your ITR. I have a Comptech Race header, and 2.5" exhaust. No intake, stock motor. I am just looking for something that has better ignition timing and has a nice and steady AFR, instead of dumping pig rich after 6500, like my car does now.
Shawn Church tuned the car. Stock block and head. Skunk 2 Stage 2 cams. 310 cc injectors. AEM CAI and a JDM 4-1 header. A/F was near perfect. If it will work for you I can e-mail it.
about those bin file from pgmfi.org,
the Int359.bin is a jdm itr bin and the Int497.bin is the usdm itr bin.
you can open them in crome, the ignition and fuel maps looks ok but if you look in the option tap, all the data looks wack because crome cant convert code. so, just open a new p72 bin and copy and paste the ignition and fuel tables from those bin.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR »</TD></TR><TR><TD CLASS="quote">I have a program that can convert Hondata files to Uberdata. So that would be fine.
Share the program, and I may have a .bin you'll love..... let me get permission from the originator to share it though.....
i need a jdm ITR with bolt ons one...
i went on that database listed above and when i open it in uberdata nothing comes up but errors. i import them "1.6<import" "1.7 import" and "1.6 import" and nothing works... heres what im doing
open.... stock GSR
then import.... ( what i said up there )
someone help me out please
open.... stock GSR
