MECHANIC LOOKING FOR WORK (CHICAGOLAND AREA)
Old Mar 6, 2005 | 05:56 PM
todapowered's Avatar
Default MECHANIC LOOKING FOR WORK (CHICAGOLAND AREA)
BEEN WORKING AND MODIFING HONDAS SINCE 1996
SPECIALTY EF'S CRX CIVIC HATCHY'S
B-SERIES SWAP 475.00 INSATLL. YOU SUPPLY ALL PARTS
+50.00 IF IT NEEDS TO BE CHANGED TO MULTI POINT
ENGINE BUILD: PRICE DEPENDS ON SETUP
HAVE FULL ACCSESS TO PROFESSIONAL MACHINE SHOP
HEAD PORTING 300.00 B16/B18C/D16 250.00 INCLUDES CLEAN UP OF CASTING
AND VALVE BOWL WORK
REBUILD HONDA BOTTOM END 280.00
CHANGE OUT VALVE TRAIN 125.00
COMPLETE REBUILD D OR B SERIES 500.00
PULL MOTOR AND INSTALL 400.00 for REBUILD ONLY
REPLACE HEAD GASKET 200.00
TIMING BELT AND WATER PUMP 175.00
WATER PUMP 125.00
CHANGE CAMSHAFTS AND VALVE TRAIN 250.00
have lots of experience work is done out of my garage have worked for speed shops in the past.
all work is backed up for good rep.
CALL ANYTIME CELL#847 980 2675 / CHICAGOLAND AREA
EXAMPLE OF WORK
91 CRX SI
1.8 B18C
TODA C CAMSHAFTS
TODA VALVE SPRINGS
SKUNK RETAINERS
SKUNK MANIFOLD
JG T.B. 65MM
PORTED GSR HEAD
TYPE R VALVES
HONDATA I.M. GASKET
TODA HEADER
B18C5 BOTTOM END
CTR PISTONS
TYPE R CON. RODS
ARP HARDWARE ROD BOLTS/HEAD STUDS
MUGEN HEADGASKET
BALANCED AND BLUEPRINTED BOTTOM END
TRANS; S1 WITH QUAIFE DIFF 4.4 FINAL
HONDATA STANDALONE ECU OBD-0
B18C1 13.5 COMPRESSION ALLMOTORMADNESS!
IF YOU GUYS WANT POWER GIVE ME A CALL!
WILL BEAT ANY LABOR PRICE OF LOCAL SPEED SHOPS
THANKS ANTHONY CALL ANYTIME OR IM ME
Modified by todapowered at 7:56 PM 3/8/2005
K-Spec
Jan 30, 2007 04:42 PM
93FastLs
Feb 23, 2005 04:36 PM
dc800
Feb 1, 2004 11:11 AM
Ink00
Sep 26, 2002 10:45 PM
akkording
Oct 15, 2001 06:54 PM
